Question about LG Washing Machines
Washing machine puts brown ''crud'' all over my washing
Have cleaned filter and bowl, but there is obviously other stuff backing up somewhere in the machine, but no idea how to pull the machine apart or where to look.
  • 1294 Answers
SOURCE: brown streaks on clothes
Click on "tags" above on this page, "brown streaks on clothes" you will see a lot of solutions. The bearing problem it is.
Posted on Mar 14, 2008
  • 188 Answers
SOURCE: iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Posted on Feb 19, 2009
jrwoodlock
  • 19 Answers
SOURCE: My Washing machine stains clothes;
Its the felt drum seal (clothes getting stuck in there and getting the greasy adhesive on them). I took a Q-tip and slid it between the felt seal and the metal, and the color and consistency of what came out was the same as the marks on the clothes.
Call a Whirlpool tech, they can replace
Posted on Aug 21, 2009
Wolfman304
  • 720 Answers
SOURCE: I have a Samsung SW62ASP top load washing machine.
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution
Posted on Dec 03, 2009
I have the same problem with my Samsung. Did you solve it?
Posted on Dec 22, 2010
Kenmore 400 washer, leaves tons of lint on clothes, no lint basket to clean, cleaning the inside of the washer doesn't help. Black clothes have to be brushed completely with a lint brush to be wearable....
most common cause is that a tiisue or something of that nature went into your wash it breaks uprt and is scattered inside the machines outer bowls,either remove inner bowl to clean it or put it several empty washes to try and get rid of it
Oct 24, 2017 | Kenmore 2942 400 3.2 cu. ft. Top Load...
My washing machine is flashing err2 and is not spinning. I have lots of clothes locked in a machine full of water! Help! wm-1460tve bush washing machine
sounds like either the pump is blocked or broken.
bring machine forward so that you can tilt it back so as to be able to undo filter cover.
Be aware, lots (and i mean lots) of water will exit so a) have a big bowl and b) only undo filter cover a little so can retighten quickly.
Repeat until all water gone, remove cover completely and clean pump and filter area.
Refit cover, put machine back on floor, put on spin cycle and if it was a blockage, machine should empty. If not, new pump time I'm afraid
Dec 08, 2010 | Washing Machines
The water won't drain out of my machine, i don't know where to look to fix this problem!
first remove the outlet hose at the back aND DRAIN MACHINE INTO A BOWL.nOW U HAVE TO FIND THE FILTER LOOK FOR A SQUARE PANEL ON THE FRONT OF THE MACHINE SOMEWHERE NEAR THE BOTTON REMOVE PLUG AND CHECK AND CLEAN
Aug 11, 2010 | Fisher and Paykel Washing Machines
How to clean water filter?
http://www.washerhelp.co.uk/washing-machine-parts/pumps.html#cl_q4
Most washing machines have a pump filter to protect the pump from obstructions such as coins. The pump filter should be at the front of the washing machine at the bottom left or right. It should be obvious (a square or round flap) but sometimes the filter is hidden behind the front kickstrip panel. A good washing machine filter should have retractable pipe at the side so that you can drain the water into a bowl. In any event, please go to this link above, this is all explained again, and there is even more direct information you need to know, the list is large.
Jun 06, 2010 | Hoover AAA140 Front Load Washer
Macine filter is not working correctly
Sounds like you've been using fab softner? this builds up like tar on the washers metal bowl. All you can try is pouring a whole large bottle 2L of white vinegar into this washer and selecting the hottest and longest was cycle and hope this dissolves the build up on the outside on the bowl. Tip never use fabric softner again or use white vinegar instead.. Tell me how you get on please.
Oct 30, 2009 | Samsung Washing Machines
Is there a filter on the wmt 03 hotpoint washing machine
We have the same machine which had the same problem, there is no filter only a colection pot at the bottom of the machine. Unfortunately even cleaning this did not solve ours, in the end I had to strip the machine down, split the drum down and then flush the brown crud which had accumulated behind the steel inner drum. Ta da problem solved!. Probably not what you'd want to do if you were not confident in attempting it but it saves buying a new machine.
Sep 09, 2009 | Washing Machines
Oil smell in washing bowl, wet pump exterior and floor puddle.
Mark, the "brown stuff" is a build up of old soap, dirt and often mildew. Yea, gross huh? The best way to get rid of it if you have a bad case (which sounds like you) is to remove the spin basket and actually clean all the crud out. Once it has been cleaned then you should do at least 1 load of wash a week on HOT and it helps keep the gunk away. Some places offer products that are supposed to remove the gunk but I have yet to find one that does. The brown stuff is not related to a bad seal on the shaft. Good luck!
Aug 11, 2009 | Fisher Paykel EcoSmart GWL15
My washing machine is not draining
You can try this: It's for the Kenmore/Whirlpool models..
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels, a good big plastic bag or a wet vac to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Apr 03, 2009 | Washing Machines
Brown dirt-like looking "gunk" coming out of the washer
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jan 10, 2009 | Kenmore 44832 Front Load Washer
Cleaning the machine. pipe???
are you using liquid detergent? this has the effect when used for long periods of making the machine smell like drains. if so, put on a boil wash with no clothes and revert to powder detergent. there is a filter which needs clearing if drain is slow.to access, remove bottom panel at back. filter is located in large pipe leading from tub to pump on the lhs. undo this pipe at the tub end and the filter is inside. some water will come out so be prepared. unplug from mains first
Apr 03, 2007 | Hotpoint WMA58 Front Load Washer
Washing Machines Logo
402 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
