Question about XION (XON-500F8X2-201) (XON-500F8X2-201) Power Supply
Can't turn on PC, Presario SR2163WM
I purchased a XON-500F8X2-201 500w power supply to upgrade my son's HP Presario SR2163WM pc to allow him to use a better graphics card. When I install the new power supply, I cannot turn on the PC with the switch on the power supply, or the case. The power supply tests out, and when I returned the original (BESTEC ATX-300-12Z REV DDR) to the PC, it works fine. Is this a motherboard compatability issue?, or a configuration issue? Or stupid user trick?
  • arnesond Sep 18, 2007
    Thanks Hughv, I did check and double check the connxn to make sure they were tight.
    I did the paperclip test on the PS outside of the pc, and it worked fine and its switch worked fine. But when installed in the case, and motherboard, ....nothing.
    That's what makes me wonder if there is an issue with the motherboard, or VISTA, or BIOS or something that I am unaware of that makes it unresponsive to the switch on the case.
  • 3 Answers
Sorry for your problems. I would suggest that you make sure the MB works with the old PSU, and if so, send the XION one back. I have 2 XION PSUs, and they give me a couple problems... If you need further advice, go ahead and ask me at [email protected] anytime.
Posted on Jul 19, 2008
  • 196 Answers
You sound like you know what you're doing, so I expect you've made all the motherboard connections(Same as the original PS). Does the switch work when you test it? If so, it sounds like the PS is DOA. I've had bad luck with cheap power supplies.
Posted on Sep 18, 2007
  • Hugh Vandervoort
    Hugh Vandervoort Sep 19, 2007
    You haven't really done a proper test. You need to know that the output voltage on all circuits is adequate, and for that you need a PS tester, or a voltmeter.
    These things are inexpensive and tell you immediately whether the PS is good: http://www.monster-hardware.com/modules....
    I've found them even at Office Depot.
    In the past, my local shop was willing to test for free, so you may have some luck with that approach.
    I'm not aware of any Vista issues with Power Supplies, so I suspect a test will find some deficiency.
    Problem Solver:
  • 13 Answers
Yes I suggest you learn basic electronics before you start fiddling and blowing things up!!
Posted on Mar 13, 2008
SOURCE:
I need a power supply model atx250w-12z
part number you need is KJ383AA, KJ383AAR
they have the dimensions that fit your computer please look for your self. Measure your power supply you have.
New PC Power Supply Upgrade for Compaq Presario SR5450F KJ383AA Computer
May 14, 2014 | HP Compaq Presario SR5450F Desktop PC
Video card upgrade compatibility for compaq presario sr1900 nx with windows 7 sp1 installed
All the information for your computers motherboard can be found here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00714521&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3190727#N534
The motherboard has a x16 PCI Express Video Card slot , so you should be able to put any PCI Express Video Card into this system. I would however refrain from putting something extremely powerful in there as you will encounter issues with the weak power supply in the system (Unless you upgrade the power supply too)
All modern video cards are PCI Express :)
Nov 30, 2013 | HP Compaq Presario SR1920NX PC Desktop
Video driver p4
All drivers are available on HP's website under the support tab. Just enter the model and serial number on the support page and request the appropriate driver.
Sep 19, 2013 | HP Compaq Presario sr2163wm Computer -...
Video card
any card with two outputs. Or two cards.
Apr 28, 2013 | HP Pavilion a420n PC Desktop
My Presario SR1720NX has a blinking green light on the back near the power supply when plugged in but no power. Already replaced power supply - is my system board a goner?
Would check the switch at the front of the pc.Have had several issues with that particular switch getting pushed out on compaqs just enough to allow them not to turn on.Would also verify that all powers supply plugs are pushed in all the way.
Apr 06, 2011 | HP Compaq Presario SR1720NX (EL435AA) PC...
I am having compaq presario sr 1931 i want to install 1gb graphic card in it please suggest me card which is compatible to my pc i tried nidia gs 8400 & 210 gs
Its really depends on the power supply. What size power supply do you have? The psu is going to be the deciding factor and weather or not you want to upgrade the psu also.
Oct 21, 2010 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Compaq presario desktop sr1503wm fan at rear of cpu box won't turn. can it be fixed or replaced? apparently the other fan is overworking and causing a loud buzzing which goes off and on again every few...
If it is the fan in the power supply, replace the power supply.
The case fan is easily replaced. Measure it (in mm) and purchase a new one. The standard fan is usually 40 mm, I think.
Oct 07, 2010 | HP Compaq Presario SR1503wm PC Desktop
Tower won't turn on. There is a green light on the back near the power cord that's flashing green.
Pull the power cord out and allow it to reset. If you still have issues you may need to replace your power supply.
Aug 05, 2010 | HP Compaq Presario Media Center SR1750NX...
XION (XON-500F8X2-201) (XON-500F8X2-201) Power Supply Logo
358 people viewed this question
Top XION Computers & Internet Experts
Daniel
Daniel
JonSnell Electronic
JonSnell Electronic
NOEL
NOEL
Are you a XION Computer and Internet Expert? Answer questions, earn points and help others
