Question about ASUS P5PE-VM Motherboard
Motherboard will not read harddrive
I.m getting power to all componets except hd. i check with another computer and the hard drive works.
i have also switch the power plugs from one drive to another and those work. but still nothing on hard drive. i also tried to go in bios and cmos and they should no hard drive detected.
anythouhgts.
  • 326 Answers
You may have a defective data cable, or controller.
You may have a defective drive.
Try to find out if the drive is spinning at all while the computer is powered up. It helps to hold a screw driver up against the drive and place the handle to your ear.
If the drive is not spinning, or if you hear a repeated click, then your drive has unfortunately become defective.
Lastly, If your drive is PATA (Or the roughly 2 inch rectangular connector) you may also try switching the direction that the cable is plugged in. Place the side plugged into your system board into the drive and vice versa.
Also if PATA, examine your drive for its jumper setting values.
If SATA, assure that your SATA controller is turned on in the BIOS.
While powering up read the screen for the System Utility/System Setup key, generally the delete Key "DEL"
Press this key during power up
Once in the menu look for Integrated Peripherals, or related topics regarding Onboard Controllers, SATA, etc.. .Assure that your SATA controllers are enabled, and while there assure that your set to boot off that drive in the Boot Options
Any of these could be a possibilty, lastly address *********** board manual one last time just to be sure.
If this information has been helpful, please rate this solution.
Posted on Apr 18, 2009
  • NitrusInc
    NitrusInc Apr 18, 2009
    Apparently FixYa has set some strange parameters for their filtering, the *'s are your main-board manual.
    Sergeant:
    Novelist:
  • 192 Answers
Hi there.
You can manually add the hard drive in your BIOS settings. Have you tried changing the IDE cable, to see if you have a faulty cable?
Tim
Gateway E3600 (Intel D845PT MB) won't boot after MS Update
This error comes when your motherbord not read properly harddrive.
for that first reconnect both connection to harddisk.Power cable and ide or sata cable.
Change SATA or IDE cable then check.
Pull cmos cell from motherbord for 10 minutes so all settings are factory defaults.
Then when you power up the computer press F1 or F2 or "del" key then you can see bios screen.
Make sure hardddrive detect in bios.
Set first boot device as harddrive.
Then check.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | Intel Desktop Board D845PT Motherboard
Cannot get external hard drive to work
- Make sure that the hard drive (HD) is properly connected to the computer.
- Try connecting it to a different computer to make sure that the HD is the problem.
- Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
To check the Disk Management:
NOTE: Make sure that the external HD is connected and turned ON.
1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
2. Select Manage and click on "Disk Management".
3. From the Disk Management, you will see a drive letters
4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
5. If there's a drive letter that disappears, then that is your Maxtor HD.
6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
Have a great day!
Oct 17, 2009 | Maxtor Hard Drive
Need new laptop harddrive
Go to either bestbuy.com or compusa.com and look for the hard drive there. The hard drive will be cheaper going thru either of those places. Also check out pricewatch.com cause you can compare prices there. Also go thru google and check out the shopping results of the hard drive your looking for as well.
Lots of places to check and the hard drive will definitely be cheaper then going thru HP.
Jul 06, 2009 | Compaq Computers & Internet
GT5034 has power, blue light on power button, no beep, no boot, sounds like fan running hard. Hard drive light is on for a while and both CD drives green lights flicker. Nothing comes up on the monitor. HD...
powersource is good.motherboard might be the problem.harddrive can be tested by putting it in
another computer and see if it boot up.to test the mother board unhook the cd drives and harddrive.turn
on the computer and see if the gateway logo comes on.if it still does the the samething with everything unhooked
then it might be the bios.you might have to flash the bios and reinstall it.to do this i recommend you take it to a
shop.if the comp runs with everything still unpluged and stops then you know that you have a wrong
setting on the harddrive or cd drive.if you got two of anything make sure that you have a slave or master.if you nned me to
write a guide email me at gamecrazy944@yahoo.com or if you got anymore questions.
Jun 29, 2009 | Gateway GT5034 PC Desktop
Exterenal harddrive unreadable
Please try it on another computer and see if you get the same results.
Mar 03, 2009 | Toshiba 120GB USB 2.0 Portable External...
Computer not reading the hard drive
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
May 10, 2008 | Balance CN6555 Notebook
New Harddrive
Most of the tower cabin are supprots scsi hdd please check whether it is IDE or the scsi harddrive .
Apr 28, 2008 | Gateway 505GR PC Desktop
Errors
no this is not the problem with any motherboard r with hard disks this is the problem with the cdrom drive ... the capability of the reading cds is less of the cd rom u r using in this first system ... once you just have a check by removing the cdrom drive of the second computer & inserting into the first comp... it will surely read that cd....
this means it s the timt to change the cdrom of the first computer .. so just buy new 1..........
Feb 11, 2008 | Foxconn NF4UK8AA-8EKRS Motherboard
Hard Disks Not Detected
Hi Alec, Chances are if hard drives are getting sufficient power (spinning hard drives are only a rough indicator) then there?s something wrong with the data lines that run from the hard drives to the controller. Check each connector on the hard drive to make sure it is plugged in securely, trace it to where it plugs into the motherboard and check them as well. They could have pulled out while you were moving things around. If that doesn?t work then I would try replacing the original video card. Let us know if this solved your issue and please don?t forget to rate the posting when we?re done.
Jan 17, 2007 | ASUS A8N-SLI Motherboard
Boot problem
Was the operating system installed on another computer? Or a computer with different hardware? If so the drivers for the hardware are not configured properly on the HD or in the BIOS. If this is the case you should format the HD and re-install the OS.
Aug 15, 2006 | Jetway N2VIEW Motherboard
ASUS P5PE-VM Motherboard Logo
203 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
