Question about Canon PIXMA iP90 Mobile Printer
I have a Waste Ink Absorber problem that will prevent printing
How do I take care of the Waste Ink Absorber? Should I replace it or just get a new printer??my canon ip90 is saying the same thing-help!
  • Canon Master
  • 19,396 Answers
If the waste ink absorber is really full, you will have to disassemble the printer removing the absorbing pad, cleaning in in a sink (this may release a lot of ink) and put it back. Sending this printer out for repairs is not worth the price, you can get a new one with roughly same amount you would pay.
By the way , when you get the Waste Ink Absorber message , usually the waste ink absorber is not full, if this is first time it happens you can reset the counter and printer will probably work.
Here there is a procedure:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Here is a discussion group on same problem.
Posted on Apr 18, 2009
Waste ink absorber full
Open your printer.
To protect hands from Ink wear thin latex (or similar) gloves
Locate the Waste Ink Pads on the inside of your printer
. They are on the right hand side and are quite small.
You can remove the pads and the holder with a gentle pull
Using a tissue, soak up as much ink as possible and clean the area around the waste ink area
There is one more waste holder in the right back bottom of the printer. A kind of sponge. There are few screws and plastic parts to be removed and this sponge needs to be washed, dried and placed again. Be careful and patient. This is no understatement. Take a photograph (even with your cell phone) so you can trace back your steps. You also need to take care as you lift the slide/carriage. Below this you find 5 little springs.
Carefully replace the holder and the pads
. Close printer.
Whilst printer is disconnected from the mains power, press and hold the power button and reconnect to ac power
Release the power button
Press the power button again
Mar 03, 2011 | Canon PIXMA iP1800 Printer
Message The waste ink absorber is almost full. Where is it?
You have to replace the waste ink absorber means that you have to replace ink cartridge.
Follow bellow steps to replace it.
  • First of all you will need these things napkin,replacement ink absorber.
  • Move the cartridge cradle center of the printing unit.Unplug the printer so that it will remain in its position.
  • Locate the waste ink absorber in their black rubber frame.It will likely be on the right side of your printer and will be located underneath the area where the ink cartridges rest when your printer is in standby mode.
  • To soak up any excess ink that may be in the pads by pressing it down onto the top of the frame, use napkin for soak up.
  • Pull the rubber frame free from the printer and carefully remove ink absorber.
  • Insert a new ink absorber pad into the printer by same inverse method.Be careful to pulling and pushing.
  • Hold the power button of your printer until it resets.
  • Wait for green power button then press and release power button again. It should blink for two to three seconds.It indicates that your printer is now reseted.
Thanks for using fixya.
Dec 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My mp150 is showing to replace the waste ink absorber. I think its all about reseting the EPROM. Can i do it in home? Can it done by any sofrware?
Oct 16, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
Full ink absorber
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 02, 2010 | Canon PIXMA iP90 Mobile Printer
Printer won't print. Says to contact service
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber full
This is a very common problems with canon printers. They are set for a certain number of prints and they need the ink absorber serviced. Now along with resetting the printer its best to replace the absorber. Here is link to site that has reset instructions.
http://ij-forum.blogspot.com/2008/08/reset-waste-ink-absorber-error-waste.html
Thanks,
Lee
Nov 05, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
Indicates waste ink absorber is almost full on cannon i9900 print
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
The waste ink absorption pads cannot be emptied, only replaced.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 16, 2009 | Canon i9900 InkJet Photo Printer
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA iP90 Mobile Printer Logo
23 people viewed this question
old marine
old marine
