Finding 192.168.0.50 for wireless eh100 router
I have a new eh100 wireless g band router, it states that i have to set up through ip 192.168.0.50, but that page cant be found, please help
  • 8 Answers
Try to login at http://192.168.0.1 it is generally the default. The Default username is: admin and leave the password blank. Hope this helps.
Posted on Apr 18, 2009
We do not know our password for netgear using the new amazon fire tv stick we just purchased from you
If you are referring to your router, is it from your Internet service provider (ISP)? If so, you can call them.
If not from them and you bought it from a retail outlet, you can...
1. open your web browser like IExplorer.
2. in the address bar (Where you type in the URL (web address like www.?) type your router's IP address example:192.168.1.1
and enter the user name and password to access the router. Or
3. Press and hold the reset button on the router and start from scratch using the router's setup wizzard making a new password.
4. Using a button located on your router use the router to give permission to allow the device to access it.
NOTE: you can go on D-LINK's web site and download the users manual and/or software for your router.
Jun 02, 2015 | Amazon Fire TV Stick
My new HP desktop is asking for PIN of wireless router. My router is Netgear N600 WNDR3400v2. All I can find is two MAC #'s and the S/N. Where is the PIN?
This router does not use any type of PIN. You may be confused as the HP wireless networking setup may be asking for the "password", or WPA2 key that secures the wireless network. This must be entered before the router will accept the client and assign it a network IP address. The WPA2 key is stored in the router under the Wireless Settings Option. Unfortunately, if you don't know the key, going there won't help you as the key is not visible.
Nov 05, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
How to connect the ASUS EA-N66R as a range extender.
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
Mar 08, 2013 | ASUS EA-N66 Dual-Band Wireless-N900...
I am trying to switch my band from 2.4GHz to 5GHz. Need detailed instructions on how to do this. I am not real computer savey.
First, Access the router configuration utility, open a web-browser (such as Internet Explorer) and enter the IP address of the router (192.168.0.1). Select Admin from the drop-down menu and then enter your password. Leave the password blank by default. (Defaults IP Address, User Name and Password Details are also written on the underside of the router).
Goto Wireless Settings - then Wireless and select 2.4GHz if you want to use the 2.4GHz band or 5GHz band if you want to use the 5GHz band. Save settings and its done.
For further details you may refer to D-Link DIR-628 Product Manual
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 22, 2011 | D-Link DIR-628 Wireless Router
I forgot ip address of my EOC 8610. how do i
Try address 192.168.1.1 in most cases this is default IP for the routers.
Sep 23, 2009 | EnGenius / EOC-8610 EXT / 54Mbps /...
My new Toshiba Satellite L300-20W will not connect to the internet via my wireless broadband connection (which is working fine as I tried another computer with it). The Connectivity Doctor gives the...
This problem is common.
This error message occures when the wireless card does not get an IP address from the wireless router. To get the wireless router to issue the wireless with a new IP address the connection needs to be repaired.
Right click on the wireless icon and click on repair.
Jul 30, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Replaced Linksys Wireless-B 2.4GHz 807.11b Router and Wireless B 2.4GHz 802.11b Wireless-B Notebook Adapter with Linksys-N Ultra Range Plus Wireless-N Gigabit Router, and Wireless N Ultra Range plus Dual...
Try resetting your IP address:
The laptop may be trying to use the IP address from the old router.
1) Click Start (assuming Windows 2000, XP, or Vista)
2) Click Run
3) Type in CMD
This will take you to a black command box
4) Type in: ipconfig/release
The chart should show your IP address as 0.0.0.0
Once this has happened, proceed to step 5
5) Type in: ipconfig/renew
You should now see a new IP address listed.
Also note that you need to set up your network key (assuming that you are using one) on both the router and laptop.
Make sure that your router is set up to perform as DHCP server.
FW
Apr 30, 2008 | Computers & Internet
WR850 Install Problem on new VAIO Laptop with VIsta
try to change your OS! frfom VISTA to XP. because sometimes the problem is in not the router rather the problem is, conflict bet. IPv6 and IPv4.
Apr 01, 2008 | Arris WR850G Router (DHWR850G)
Unable to get IP coming back from sleep mode
WEP Security is not strong enough and can be comprise within min! Buy a new print server it will make you sleep better and happier! Setup your IP as Stactic especially on the print server it needs to stay the same Log into the router and change the password, and look at your ip range, if your are using zone alarm or any type of firewall the ip range must match.
Coach J
Have a great 2008!
Jan 07, 2008 | Linksys WRT300N Wireless Router
Computers & Internet Logo
881 people viewed this question
David Payne
David Payne
