Question about Whirlpool GBS277PDS Electric Single Oven
How to get the glass front back on oven door of Whirlpool range
I'm having a problem getting the glass back on the oven door of my Whirlpool range #RF377PXGQ0. I took the door apart partially to clean grease that had built up behind the glass. While trying to get the glass back into the frame, I broke one of the tabs on the bottom of the vertical pieces. I purchased the entire assembly kit, but am hesitant to attempt reassembly for fear of breaking the new part (they're very expensive for what you get). I struggled with that door for hours to no avail before finally calling it quits. I've since bought the new part - the whole assembly - but fear breaking the part again. Any advice on how to deal with aligning and deal with tension on the clips?
  • stevecaddel Apr 26, 2009
    We have the same problem with a different model RF38SPXEN0. Broke the tabs, and couldn't remember if the vertical pieces went inside or outside the glass. I thought they went outside, but it was physically impossible to put them in that way.
    New Friend:
Ok. Heres what I was dealing with....Dissasembled. NOW (after you scrubbed everything to your liking try this.
1: With the door laying "oven" surface down on a flat surface. Gently place glass sheet/pane down squaring it up evenly as you can.
2: (Might sound strange) Grab the door handle and reposition it where it needs to go and slide the glass in the "ledges". Even everything up square as possible. Insert screws(2), but do NOT tighten all the way.
3: Now you have 2 (L & R) uprights. Insert "handle" end of uprights first, then align carefully the "tips" into the holes, and then snug the oven handle screws.
4: Carefully align the metal "base" channel/seat with the glass so the window/glass seats on the bases slots/shelves. Align all holes and insert screws (4 - 2 screws on both sides of base), finally align the center screw and tighten snug.
5: Replace door on Range Unit ande get cookin again!!
Hope this helps. I think its a poor design to let anything inside the door. Nice Range/Oven unit. Just a bad door design in my opinion.
Oh Yeah. The door hinges only took me 4 months to figure it has built in hinge locks. THEY are VERY convenient and once you know how they work. They are an AWSSOME invention for what they do!!
Posted on Jan 19, 2013
Do you have it set to clean. thats usually the only time it locks
Posted on Nov 09, 2009
Cracked inner oven glass window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 16, 2011 | KitchenAid Ovens
Cleaner has gotten behind the front glass, how can i remove the front glass? thankyou
You can use it for getting to the glass also...
heatman101
Dec 10, 2010 | Ovens
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Condensation in oven door glass after steam clean
No solution--but I have the EXACT same problem--brand new oven and first time steam cleaned used. Wondering if you got any resolution with this...
Jun 30, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Can't put door glass back in Whirlpool RF396LXE2 range
The answer is not as hard as it seems. I just tried for 10 minutes unsuccessfully to put the glass back in the two side tracks. Well the glass actually goes in front of them, the top holds the glass in place.
Apr 05, 2009 | Whirlpool RBS275PD Electric Single Oven
Broken glass front panel
Have the make and model number and contact any appliance parts supply, they can order the glass. or call a service man who can do it.
Nov 01, 2008 | Ovens
Whirlpool GBS277PDS Electric Single Oven Logo
1,112 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De GO PATS
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
