Question about Kenwood KAC-8401 Car Audio Amplifier
Amp not powering up correctly.
I have a kenwood KAC-8401 amp that has worked well in the past. one day when i went to turn my car on it wouldnt power up at all so i checked all my fuses and they were good, so i checked my wiring and it was good. The amp now powers up but only puts on a red LED light when it should be blue.
  • 67 Answers
Check transistor of the unit 1 or 2 tans. bad use a tester. the unit is overload protected. replace the deffecteve parts
Posted on Sep 19, 2007
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
I have a kenwood kac-8452 4 channel amp that makes the speakers pulse after the volume gets turned up to 10. I also have a kenwood amp doing the same thing with my subs. any ideas?
Its not pulsing, its called clipping. The sound is being clipped due the amp being pushed past is power capacity and distorting the signal. This will damage your speakers very quickly. No amp should be turned more then 3/4 up. If its not loud enough you need to purchase a larger amp or be comfortable with the wattage it produces at 3/4 volume. You may also have speaker wires touching/crossed causing th issue.
Sep 10, 2009 | Kenwood KAC-8452 Car Audio Amplifier
How can i power on without the cd player, just only aplimifer
Impossible. You have to have not only a power and ground supply. But without a remote wire the amp won't know that you are trying to power it on. The remote basically sends the power to the amp when you turn on your radio.
Jul 08, 2009 | Kenwood KAC-8401 Car Audio Amplifier
What does it mean when the power light blinks on the amp?
genrally kenwood amps are power hungry amps so after playing for a while if it doesnt get the amount of amperage to make it work it will shut down cus you car cant charge the battery long enough for the use of that amp so my idea is try a farad capacitor and see if that helps good luck .......tk
May 29, 2009 | Kenwood KAC-7252 Car Audio Amplifier
Kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
Apr 16, 2009 | Kenwood KAC-X1R Car Audio Amplifier
Kenwood KAC-9152D I THINK IT SHORTED OUT BUT HOW CAN I FIX IT?
Either can either do it yourself like the guy above or take it to your local car audio dealer :)
Upfront Audio
Apr 10, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-8401 light goes from blue to red when turned on
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 29, 2008 | Kenwood KAC-9152D Car Audio Amplifier
My amp wont put out any sound
You need to confirm that you have a good ground, and 12v on the terminals of the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Dec 26, 2007 | Kenwood KAC-8401 Car Audio Amplifier
KAC-8401 Shuts off Blue light still lit
HI RLF,
You might want to turn your Gain setting down a little. Also Look to be sure you have enough air flow around the amp. If it cannot breath, the heat from the amp will build until it wigs out. Use your Ingenuity to get more air to the AMp.
Nov 05, 2007 | Kenwood KAC-8401 Car Audio Amplifier
Amp won't turn on don't know if amp is fried
Very possible that you have a blown power supply in the amp. If you are running a mono amp then there is a very good chance that you have loaded your amp with too low of a speaker impedence and fried the power supply and maybe the output section of the audio area. Hope this helps.
Mar 30, 2007 | Kenwood KAC-8152D Car Audio Amplifier
Kenwood KAC-8401 Car Audio Amplifier Logo
260 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
