Don't know how to start it
I have central heating in the unit i'm renting, but i don't know how to start it. It has an ignition switch, a red button and black button, as well as a knob that has high and low on it. It's a vulcan but i'm not sure what model it is. Can anyone help?
  • teganbull Apr 18, 2009
    I have no idea if the thermostat is on... There's only a panel with the buttons and ignition switch etc so i don't know where else to look. It's gas heating but it's also connected to a powerpoint.
  • 600 Answers
Is the thermostat on? also there should be a master switch near the unit itself (with a red plate) make sure that is on (UP) also is it oil or gas fired?
Posted on Apr 18, 2009
  • mrninja
    mrninja Apr 18, 2009
    you need to find the thermostat-- should be on the wall about shoulder height and be around the central living area, if you cannot find one, check the unit otherwise there may be one master one that you dont have access to
I can't get any my system to heat the water. The main electricity went off and on again and maybe it needs resetting but button not responding
Try unplugging the unit for 5 minutes and see if it resets, if no joy you have a possible burnt control board due to a power surge.
Aug 09, 2016 | Water Water Heaters
I have a 94 honda civic ex and it's having
I would have the ignition switch checked, not the key switch but whats behind the key switch. Ignition Switch!
Jul 02, 2013 | Cars & Trucks
Peugeot central locking fault
It might be in the switch it self if the switch does not work then the key switch does not work either
Jun 09, 2013 | Car Audio & Video
My keating fryer heats the oil fine to temp set on thermostat but will not re fire when oil temp drops unless I push the high limit button. Don't know if the problem is the themostat or high limit...
Sounds like the thermostat is working because it does heat to the right temperature, right? The high limit switch is to shut it down when it gets too hot, so why that helps the unit relight and heat up is strange? Is this gas or electric? Since hitting the reset or high limit button is what is working, I would start there, and replace that... I don't think either part is super expensive, so replacing both wouldn't be too expensive, especially since you have one of the best fryers ever made... Keating is number one in my book, and I know they are expensive to start with, but these two parts shouldn't be much....however I would start with the high limit switch or reset button... If you need a part, we can get you a price....I'm Susan with Restaurant Equipment Outlet, Cincinnati, Ohio, 888-542-5959, or you can ask for Paul too. Thanks, Susan REO
Sep 12, 2011 | Keating Instant Recovery 20AA (NG) Deep...
If you are using this inside your home with central air running do you have to vent it to an outside window?
Yes, it must be vented to the outside, even if you're using central AC, too. The reason being is if you don't vent it to the outside, the hot air and humidity that normally goes thru the duct and out the window, will stay in the house and your Central AC will have to run longer and harder to overcome this rise in heat and humidity. In addition, the room that the portable AC is in, will get extremely hot & humid.
Hope this helped you. Please let me know. Thanks.
Jun 15, 2011 | Haier CPN12XH9 Portable Air Conditioner
When i turn my central air on the fan not running so do the motor and i don't know why. i have this goodman central air for four year now.
I had the same problem with the fan not running and the compressor hard starsting. It turned ouot to be just needing a new capacitor. I also bought a "hard start" unit to hook to the new capacitor to ease the burden of the starting in case there is low voltage to the unit during high usage times. The very first thing I would check would be the capacitor. Don't fool with this yourself unless you first discharge the capacitor, as this is very dangerous unless discharged first.
Jun 02, 2011 | Goodman CKL42AR42 Air Conditioner
Buzzing alarm sound before ignition
The yellow or red light would mean a control board that is bad or going bad. The buzzing sound could just be the transformer not uncommon to hear a buzzing sound from the transformer.
Dec 16, 2009 | Heating & Cooling
I can't lock the car using the remote key. the light flashes on the key but does not lock the doors
try reprograming the remote, if that doesn't work u may need a new remote these are the factory instructions.
1. Switch ignition on with a key (don’t start the engine!); leave key in the ignition.
2. Mechanically lock vehicle at left front door, using second key.
3. On remote unit, press "Open" button once. A short horn signal will sound.
he "Open" button is pressed once for programming the first, or a single,
remote unit.
�� When programming additional remote units for the second, third or fourth
memory addresses, press the "Open" button two, three or four times, in
one-second intervals.
�� Example: press the "Open" button once, wait 1 second, then press once
again to program the second remote unit.
�� After 6 seconds, press "Open" button once to activate the coding ocess.
4. The remote unit will now be coded, and it can be used to unlock the central
locking system. Switch ignition off.
The key must be removed from the ignition before the remote unit can be used to lock
the vehicle.The coding process can be repeated up to 4 times for additional remote units.
In between each remote unit coding, the ignition must be switched off.
Apr 10, 2009 | 2004 Volkswagen Jetta
10yr Vulcan Central Heating unit. Had tech come out and said main fan unit was faulty. I replaced myself and still not working. I discovered the O/Temp manual switch had cut off power. When I reset the...
I have the same problem, heating unit will not ignite, it trips out, i go into the roof cavity and remove the top of the unit (4 screws) and there is a motherboard, it has a Green light flashing what tells you the type of fault it has, mine has 3 Flashes telling me it a combustion air pressure system failure, ithen push the reset switch and it starts to initiate, a red light comes on and then it ignites and it will work for about 30 minutes to an hour and a half.
Hope this helps
Shane
Sep 08, 2008 | Heating & Cooling
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
