- Have belt in position around drum and by motor. Question now is does the belt have to go around the steel pin coming out of the center of the motor and the plastic ribbed pully wheel, or just the pully wheel. Belt is ribbed on inside. Steel drive pin on motor is not ribbed where this belt would go. I'm inclined to say it should not go around the steel pin but just want to make sure.
The belt is acessable from the front of the dryer you can remove it by popping the top up then taking off the front of the dryer off the drum will come out now place the belt around the drum and put back in now the belt goes around the drum the motor pulley and under the tentioner pulley replace front and top and you are good to go thank you
Please rate me
Comments:
Apr 20, 2009
- The belt is acessable from the front of the dryer you can remove it by popping the top up then taking off the front of the dryer off the drum will come out now place the belt around the drum and put back in now the belt goes around the drum the motor pulley and under the tentioner pulley replace front and top and you are good to go thank you
Please rate me
Apr 20, 2009
Please rate me
Was this helpful?
Yes
No
Popular Solutions for Bosch Axxis WTA 3003 Electric
I cant get the iron dry buttom to turn off. with it on it wont complete dry anything because of the...
(More)
I cant get the iron dry buttom to turn off. with it on it wont complete dry anything because of the humidity detector. I have tried to reset the dryer by unplugging it.
The tension pullies were removed in my absence and I need a diagram of how the pullies are mounted...
(More)
The tension pullies were removed in my absence and I need a diagram of how the pullies are mounted and how the belt is fitted around them.
I cannot locate a heater element for a Bosch tumble dryer WTA 3000. Any idea where I can get one at...
(More)
I cannot locate a heater element for a Bosch tumble dryer WTA 3000. Any idea where I can get one at a reasonable price.
