Question about SanDisk 4GB microSDHC Memory Card
I can't download music to my micro SD card.
I formatted my card to my LG UX260, but when I try to plug it into my SD port via adapter the computer won't recognize it as a separate piece of hardware.
SOURCE: Micro SD 2 GB just stopped working
I had this same issue added music to my card did a safe remove from my comp. placed in phone and it stated "No memory card inserted" and wont read in adapter in computer Im so Sad i lost all my pics/memories :( it just means that the Card is Fried (Burnt Out) no way to fix this their just like SIM cards In 3G phones and if the copper bars get scratched or bent just the slightest bit it kills the SD card.
Posted on Oct 29, 2008
SOURCE: pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Posted on Jan 05, 2009
SOURCE: micro sd card not working
I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
Posted on Feb 10, 2009
Schmead10
  • 650 Answers
SOURCE: micro sd memory card not recognized
Make sure your usb mode is msc plugin your sansa and go to my computer click on Sansa folder and you should see your removable disk this is your expansion card
Posted on Apr 18, 2009
Dgby714
  • 41 Answers
SOURCE: I HAVE BOUGHT A SANDISK 4GB MICRO SD HC CARD
What phone? Check user manual of phone to see if the music has to be in a certain folder on the card. Try reformating the card.
Posted on Apr 25, 2009
HAVE PHONE, HAVE MEMORY CARD TO DOWNLOAD MUSIC; WHAT'S MY NEXT STEP?
plug the device up to the computer with the micro sd installed and open to view files.........next save the music to the music folder in DCIM. there ya go.....and if you have a micro - mini sd adapter then you can just pop it into your computer after you have formated it on your device. But remember that if you do it out of the phone you will have to format the card by going to the sd menu and selecting format.
GOOD LUCK AND PLS RATE THIS POST
Feb 10, 2010 | Samsung SCH-u740 Cellular Phone
I have a T-Mobile G1 with a micro sd card; trying to sync??
most mini sd cards come with a full-sized sd card adapter that the mini slips into. You can then slip that in your computer if you have an sd slot or sd reader.
You can also buy very inexpensively, a usb port mini sd reader that you can plug directly into your usb port on your computer. Then after you'v dragged and dropped the files, you can put the mini sd back in your phone.
Jun 16, 2009 | SanDisk 2GB microSD Memory Card
How do I use the SanDisk adaptor and the SanDisk 2GB microSD
The micro card (the smaller one) can be used alone in a port that accepts (microSD ports)such as those on a Sansa c240, c250, e250 etc.
If you have a regular SD slot (larger than microSD) then you plug the micro card in the adapter and plug the whole into a regular SD slot.
Plug the card in your computer and copy paste the files. Or plug the micro card in an MP3 player that accepts it and use you music transfert software.
You only have one card (the micro SD one), which you can use in two possible slots.
Hope it helps.
May 19, 2009 | SanDisk 2GB microSD Memory Card
Doesn't show mp3 files on micro sd card
You have to drag and drop only the MP3 files into the music folder. If you have them organized and in folder by artist, drag only the MP3s into the card's Music folder.
May 05, 2009 | Lands Phones
LG KC550 PC Suite Problem
I speant Hours swearing at my phone because it would not read my music files, Tried the card on many different phones which would take Micro SD and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro sd card in that and then putting your music files into the "sounds" folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents, Sounds, others and Videos on your Micro SD card. Format the card by going My computer, Right click the Card reader (with you Micro sd card inserted) and click format. Takes a few seconds. Insert the card into the phone, the phone will auto put the folders on the card. Then go to step 1 (above) and start again.
Hope this Helps guys.
Apr 04, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Memory card lg kc550
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
Nov 13, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Cant transfer music file to my lg ku990 via usb from pc to phone
Instead of loading the music manager, click on file in the LG Suite box, and then click 'content'. This will connect without a problem (at least it did for me, despite music manager not working), and then drag and drop music from your pc files, onto your phone. Hope this helps.
Jul 27, 2008 | LG KU990 Viewty
Saving music on my micro sd..
I'm not sure about your phone, but with the one that i just purchased i bought a SD card reader that plugs into the USB port. The micro SD that i bought came with an adapter and goes right into the card reader. Your computer will recognize it once you plug it in with the card in it. You can find one at walmart in the camera section.
Apr 16, 2008 | LG CU400 Cellular Phone
why cant i get my micro sd to show on my phone
Oct 26, 2007 | LG CHOCOLATE VX8500 Cellular Phone
SanDisk 4GB microSDHC Memory Card Logo
121 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
