Question about Combination Televisions
Very wierd Toshiba video problem
I obtained this Toshiba tv/dvd/vcr unit a few months ago. It had been dropped and no longer worked. Model MW26G71. The main pcb was damaged, the high voltage transformer was completely broken away from the circuit board. I repaired the board to somewhat functional status but had a distorted picture. The picture looks like the degaussing circuit is energized all the time. I can e-mail a picture of it for examination. So I figured that the board had fyther problems.. Replaced main board and still had the wierd picture, replaced the power supply, no help. Replaced the video chip on the VCR board, no help. The next part is 200.00. Would like some opinions on this problem, hate to trash a good tv.
  • 1,139 Answers
Re: Very wierd Toshiba video problem
Hello techman2429m, It looks like you may have a color convergence problem. when you dropped the TV the convergence/purity rings on the neck of the tube may have shifted or by changing parts you may have thrown off the convergence. I would suggest using a pattern generator and adjusting convergence also adjusting the purity settings. This I believe will clear up your problems.
Posted on Sep 18, 2007
0 characters
3 Points
My toshiba dvd/vcr combo suddenly wont read dvd disc
Maybe the lasers ok but the disc motor is not spinning the disc.
Apr 28, 2014 | Combination Televisions
No sound, no picture
Try with external monitor and let me know did u see ur desktop with external monitor?
Nov 24, 2007 | Toshiba MW26G71 26 in. TV/VCR/DVD Combo
Dish Network Combo TV/DVD Remote Codes
CODE Broksonic TV/VCR 748 Goldstar TV/VCR 747 Panasonic TV/VCR 747 Quasar TV/VCR 747 Samsung TV/VCR 738, 755 Sylvania TV/VCR 756 Zenith TV/VCR 747 Aiwa TV/DVD 751 Apex TV/DVD 757 Broksonic TV/DVD 752 Konka TV/DVD 753 Panasonic TV/DVD 734, 765 RCA TV/DVD 749 Sansui TV/DVD 754 Sylvania TV/DVD 764 Toshiba TV/DVD 750 Go Video DVD/VCR 692, 693 JVC DVD/VCR 689 RCA DVD/VCR 690 Samsung DVD/VCR 738, 667, 691 Sony DVD/VCR 768
on Jun 06, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Set won't turn on. has a buzzing soune
Power supply board is dead.Replaced the power supply board will solved this problems.Tries, for a refurbish power supply board.
Feb 20, 2010 | Toshiba MW26G71 26 in. TV/VCR/DVD Combo
After turning on tv 5 to 10 minites later a black
this is closed caqption go into menu and turn it off or if remote has cc button turn it off with that.
Aug 11, 2009 | Toshiba MW26G71 26 in. TV/VCR/DVD Combo
Need Toshiba remote access code for this product so I can use a universal remote to operate the VCR and DVD
remote codes are set by the manufacurer of the remote not the tv. if there are any others not listed in instructions for remote, the manufacturer of remote would have them. most combo unit are not able to be programmed into universal remotes due to the fact that there are alot of specialized function buttons on original remote. you can obtain a replacement remote thru toshiba
May 16, 2009 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Dish Network remote code for RCA 20F510TD TV/DVD
hello and please help.
want to know the codes and way to program this rca dish remote model RCR500SAM1 for my Toshiba tv.
ive done it a few years ago but forgot.
so i need the codes for toshiba tv and way to program this rca dish network remote.
Jul 26, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Panasonic PV-D4743S combo DVD/VCR player won't eject DVD
This unit has seperate power supplies for the DVD and VCR side and the DVD side supply seems prone to failure. I have not isolated the cause, but can tell you this will require a component level repair. Unless you are a tech you may as well buy a new unit.
Sep 22, 2007 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
Combination Televisions Logo
197 people viewed this question
Top Combination Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Combination Television Expert? Answer questions, earn points and help others
