Question about Garmin StreetPilot c340 GPS Receiver
How do i set a home location on a garmin???
I enter my address and it still says kansas how do i fix that
  • Anonymous May 02, 2009
    its not set to my home location, how do i change that?
Call someone who has a garmin
Posted on Apr 19, 2009
No matter what address i input, it can find the location but when it start navigate, the map turns out a location in Kansas..i dnt know why is that..i input washington state address
You need to change the State. When you go to put in the address does it show the state as Kansas. If so press change state and change it to Washington.
Jul 19, 2010 | Garmin nuvi 260W GPS Receiver
My Garmin is stuck on my last destination.
Your Garmin's Home Location has been changed.
Solution: You must reset your Home Location.
Go to Main Menu.
Select: Where to?
Select: My Locations.
Select: Set Home.
(Message: A Home Location Already Exists. Do you want to change this location?)
A. If you are at your home location, select: Yes, use my current location.
B. If you are NOT at your home location, select: Yes, enter my Address. Enter your Home address.
Press "Save".
Jul 25, 2009 | Garmin nuvi 350 GPS Receiver
New Garmin 330 stuck on kansas
Take the unit outside and turn it on. Then select View Maps, at the top of the screen it will say either "Locating satellites" or "Acquiring Satellites". Once the garmin has locked onto the overhead satellites, then it will say "Ready to Navigate".
Locating Satellites take longer than Acquiring Satellites.
Jun 10, 2008 | Garmin StreetPilot C330 GPS Receiver
GPSC340
You need to go outside with a clear view of the sky and get a satellite fix with the unit turned on (usually a couple of minutes), Then the maps will show your current position. By entering your address you are trying to create a route from current position to your destination. By default the current position is set for Kansas (Garmin US office), but once you have locked onto the satellite your current postion will be the last position before the unit was turned off.
Dec 30, 2007 | Garmin StreetPilot i3 GPS Receiver
Home address
Click 'Where to', select 'My Locations' Select 'favorites' Click 'Home' then select 'EDIT' in the lower right hand corner. Than selet 'DELETE' that should clear the home addy out for you.
Best of luck.
Dan
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Location says I'm in Kansas
I got stuck in Kansas also. But, now I'm not in Kansas anymore! Are you trying to set your Garmin up indoors? That was my first problem. Go outdoors and try it. I did that and Toto and I were still in Kansas. SO, I pluged it inot my cigarette lighter and drove down my driveway. It took a few minutes for Garmin to locate a satalite, but once it did I was all set. No problems since, hope it works for you. I really enjoy using my Garmin. I'm one who ofter ends up on the road less traveled so, Garmin has come to my rescue a few times already. Have fun and say hello to the Wizard of Oz for me!
Christine
Dec 25, 2007 | Garmin StreetPilot c340 GPS Receiver
Locating Satellites
I had the same problem and i plugged mine in the car for about 10 mins and it works great now
GARMIN BASICS FOR THE ELECTRONICALLY CHALLENGED
first turn it on and let the unit acquire satellites to find your home state. Then you can set up your address as your "home location". When I first set it up, I was able to pick up the satellites in my bedroom (scary....)...everything worked just fine.
Nov 26, 2007 | Garmin StreetPilot c340 GPS Receiver
How to change home map on used Garmin i3 street pilot
Hello. Had the same problem and just solved it.
Do this.
Tools -> Manage My Data -> My Locations. Position to Home and then click Manage -> Change Location ..
Cheers.
Sep 15, 2007 | Garmin Map Source City Navigator
Garmin StreetPilot c340 GPS Receiver Logo
142 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
