Question about Dryers
Won't start; makes faint noise
Kenmore 70 Series Dryer Moved to a new place. Had to change to a 4 prong cord. Dryer won't start, but makes a faint noise. Dryer says 240v/28a, power outlet says 250v/30a. Any help greatly appreciated.
  • Jerome Barbin May 11, 2010
    I would first check to see if you have proper ground to the receptical. good luck.
    President:
  • 331 Answers
Pete,
Check your wiring first. Should be something like this... (disregard the tacky comment, I made this for someone else)
Make sure all connections are good and tight.
After you have verified the wiring, let me know if it does the same thing, OK? ('cause it may be that the motor has seized. If that's the case, we'll step through that then)
SG
Posted on Apr 18, 2009
Kenmore Dryer Model #11060932990 Proper grounding when changing 4 prong cord to 3 prong.
According to the National Electric Code, you will need to install a grounding strap from the frame to neutral in a 4- to 3-wire conversion.
Jan 18, 2014 | Kenmore Dryers
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Kenmore Dryers
I have a Frigidaire FAFS4473LW Steam Washer- 3 prong. I moved into a new place with a 4 prong. Do I need a 4 prong cord, or can I change the 4 prong adapter on the wall?
Hi nancy huerta...
You can change the cord or the receptical...
It will be easier to change the cord...
Purchase a four prong plug cord that will fit into your receptical, then wire your dryer for 4 wire instead of three wire use.
To see a picture and explanation of how to wire your dryer for a 4 wire plug go to the following webpage.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 06, 2011 | Frigidaire GLER331A Electric Dryer
Moved and the new place has a 4 prong outlet. i need the wiring diagram to switch from 3 prong to 4 prong power cord
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2010 | Dryers
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Kenmore 70 series model 97576200
You have a bad thermal fuse , usually caused by lint blockage from the filter or vent hose .
Jul 06, 2009 | Kenmore 659 Electric Dryer
I don't have the same plug as the one on my kenmore 70 dryer
Hi, You can either change the outlet or change the cord. Easiest would be to get a new caord. Make sure you get the right one. There are two different ground posts.
One is straight and one is L shaped.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Dryers Logo
74 people viewed this question
Top Dryers Experts
