Question about Sony Handycam DCR-TRV460 Digital Camcorder
Playback Hi, I have been copying my tapes from my Sony to DVD with success until I experienced tracking problems which seem to essentially be the digital tapes or at least 80%. They play with hesitation and skips like an old LP. I have nearly 25 tapes to burn and of course this camera is now going the way of the dinosaur so I cannot replace it easily. I look forward to your suggestions.
  • Amiles Sep 19, 2007
    Thank you. I was able to locate the last surviving cleaning tape for this particular model and bought it. So, we'll see what happens.
    I am assuming that I can locate information on changing the tension of the video heads in the manual but if not.... can you help again?
    Thanks
There can be a lag of audio to video if you are recording extended parts without stopping and creating chapters. I noticed this when recording 1 hr to dvd. If I break up scenes to 15 min or so it seems to work better.
Posted on Mar 18, 2008
  • Larry Stiles
    Larry Stiles Nov 24, 2010
    tension on many models is done by replacing the reel tables. I can rebuild them however. It involves taking them apart and stretching the spring a little.
  • reotrucks Nov 24, 2010
    Is this something I can do or am I better off sending the camera out to a repairman?
    reotrucks.
    Champion:
  • 288 Answers
Most likely needs to have the heads cleaned, running that many tapes can clug your video heads. if this still does not work the take up tension might be a little low. you can fix this for free, but try having it cleaned 1st.
Posted on Sep 18, 2007
  • Larry Stiles
    Larry Stiles Sep 19, 2007
    here is the deal on the tension adj. the take up reel , the spindle on the right as you look down into the mechanism ,must be removed taken apart with your fingers , carefully and the spring inside it has to be stretched, not to much, but try and make this coil spring about 1/2 again as long as it was, twice as long is to much. reassembly the take up reel and snap it back in, it's a snap. do this adds more pressure on the felt clutch in the reel which will increase torque on the video head. I'm not a big fan of the cleaning tapes which just move the dirt around. they should be cleaned by hand with alcohol cleaning sticks ,only cleaning sideways, never up and down, then dried with compressed air. good luck
    I am having similar problem with my 6 year old TRV460. Do you have an illustration and step by step on how to do the tension adjustment.
SOURCE:
VCR playback issues
I had a similar issue with a DVD player, in that it wouldn't play any commercial or rental DVD's, but it would play them if I burned a copy on my laptop. Turned out to be board inside the machine. I had to replace it.
Jun 18, 2008 | Philips Magnavox DVD/VCR Dual Player
HI, i try to copy a Hi8-Tape to DVD, t works but i can't play it on another DVD-Player. Whats the problem. Thank's.
Depending on the format of the DVDs you record, some may not be compatible for playback on other DVD players, even if you FINALISE the disc in this recorder before playing it anywhere else. Assuming you are using the correct DVD format (for example, DVD-R), did you finalise the disc in this recorder after transferring your tape? if not, that would be the reason why the DVD won't play in another machine (I am also assuming you have everything set up correctly to enable smooth transferring - picture, sound, etc.).
Most modern DVD players recognise various disc formats (+R/-R/-R DL etc) but all of these must be finalised in the appropriate drive prior to make playback anywhere else possible. There should be a menu option or similar on this model recorder which would allow you to finalise the recording - you should only do this if you are completely happy with what you recorded, and it turned out OK. Until you finalise the recorded disc it will not work anywhere else but the deck it was written in.
I hope there is no major issue with the deck in this unit which would prevent you from finalising your discs - and achieving some success with playback in other units. The last thing anyone would want is a batch of drink coasters.
Feb 11, 2011 | JVC DR-MX1 DVD Recorder/VCR
Copy tape to dvd using Q-VHQ 760 & Pinnacle instant dvd recorder. Playback looks great, unfortunately there is a thin fuzzy line at the bottom which never changes. My question - how can I fix this ? ...
Check the edge of the tape to see if it's wrinkled. That is the most common problem that shows that line. You may be looking at the head switching pulse too. Since your VCR has no tracking adjustment, it has to be done with special tools, an oscilloscope and a voltmeter. Not an easy task.
Feb 15, 2018 | Quasar VHQ760 VHS VCR
Tracking seems off
I have had the same problem. There is no way to manually adjust the tracking on this Hitachi, or on most 8mm cameras, for that matter. I copied all of my more recent tapes to DVD first (2 copies of each) and then I went to the oldest tapes, which for some reason were OK. When I got to one tape that gave me trouble, I just let it play in the camcorder for about an hour. It adjusted its own tracking so that the picture was OK. Then, I rewound the tape and copied that one. I still have 2 tapes that will not adjust. I am going to send those out to a copying service. I hope they can adjust the tracking and make the copies I need.
By the way, I used this camera and a Panasonic DMR-E55 to make the DVD copies.
Jun 04, 2008 | Hitachi VME545 Camcorder
Why wont it play LP taped tapes?
Tracking is very sensitive on hi-8 tapes in LP mode. This recorder will record and playback in LP mode. It is however recommended that if you record in LP mode that you use the same camera to play it back, that it was recorded with, or you might have problems.
Also from what I can find online, the TR427 is just an video8 camera not a Hi-8 so if you are trying to play Hi-8 tapes on it, it won't play right.
Nov 03, 2017 | Sony Handycam CCD-TR427 Hi-8 Analog...
Playback
Recording and playing a new tape worked for me too. Thanks!
Mar 17, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
Old Sony Handycam Video 8 CCD TR36
Head alignment (re-aligning the tracks) is not something we as owners can undertake - it has to be done professionally.
You can however quite safely clean the heads by using one of the dry cleaning tapes sold for the purpose. I have used an 8mm/Hi-8 cleaning tape made by TDK for a number of years with good results. Remember that if your heads are dirty both recording and playback will be affected and once you have cleaned the heads you need to test the camera by recording new footage and then playing it back to see if matters have improved. Good Luck.
Dec 27, 2007 | Sony Handycam DCR-TRV480 Digital Camcorder
Won't playback copied dvd's, only commercially made ones.
Read here and we can see that other people have both trouble and success running back ups on this device: http://www.videohelp.com/forum/archive/anyone-experienced-with-b-u-s-playing-on-a-sony-dvp-s7000-t283487.html So... That tells us this device is finicky IE it requires a high quality burn. DVD burners have varying levels of accuracy. To improve your burn: -SLOW the burn speed for increased accuracy -USE DVD-R only as it is the most compatible -Use those Sony's DVD-r's at wal-mart or KMART because Sony makes DVR's and everyone else buys them from generic Taiwan manufacturer and relabel I bet this will solve your problem. After you get a successful burn at 2x try 4x then 6 etc.
Aug 27, 2007 | Sony DVP-S7000 DVD Player
Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony Handycam DCR-TRV460 Digital Camcorder Logo
182 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
