Question about Lowrance LCX-25c GPS Receiver
LCX-25C seems to be cycling on & off when in the sonar mode.
Last year, while fishing, my LCX-25C started pulsing on & off when in the sonar mode. It had worked fine the day before, but unexpectantly started to act up. Initially I thought I had a fuse, battery or connection problem, but those all checked out okay. I ended up taking the unit to a marine electronics shop and they tested it with their bench transducer and said it worked fine and I probably had a defective transducer, so I bought a new transducer and intalled it on my boat last fall. I haven't had it in the water yet, but it seems to be acting like it did before I replaced the transducer. Is it possible that I bought another defective transducer or is there something else going on here. Please help, fishing season is quickly approaching and I don't want to have to ship it to Lowrance unless absolutely necessary.
I also tried correcting the problem by performing a soft & hard reset as recommended on the Lowrance website, but that didn't seem to help either.
Brownie in Minneapolis
I have a lcx-25 from year 2007 with same kind of problem. Service found o lot of condensed water inside. These devices are not water or gas proof. There was oxidized connectors etc. Maybe local electronic mechanic could help you.
Posted on Aug 11, 2011
Did you ever get your problem fixed, I having the same issues.
Ken
Posted on May 02, 2010
  • gphskroch Jan 26, 2011
    I am having similar problems. When I am on the water, all of a sudden the unit thinks it is in 0.9 ft of water and locks up. This especially happens in shallower water (< 20ft). When that happens the ticking sound coming from the transducer stops and the graph stops scrolling. If I wait a while (10 minutes), the unit starts to work again. Then it happens over and over.
    When I called Lowrance they said it sounds like something internally wrong with the unit. I told them a local fish electronics store bench-tested it last spring and they said it worked fine. Must be the transducer. So I replaced the transducer and the same thing continued to happen. It also loses bottom at high speeds. I told Lowrance they can't just do a simple bench test, otherwise they will get the same result Fish-lectronics did. Well they tested it for
    4 days and did not find anything wrong with it so they are sending it back and charging me $60 for nothing.
    Any idea?
Lowrance lcx 26c will not power up
run power leads straight off batt.check inline fuse then try to power it up if no power then sounds you have a bad key pad
Nov 02, 2013 | Lowrance LCX-26C HD Recording Sonar
My depth finder keeps loseing the bottom and just flickers the last reading
Hi, if this happens when stationery check the angle of the transducer, if it only happens when moving check the height of the transducer also. Regards Phil
Jul 02, 2012 | Lowrance Lcx 38c Hd Fish Finder Gps (200...
Transducer loses bottom at any type of speed greater than trolling. Worked fine last year with all the same setttings. All I can think of is , maybe the battery is low. The boat just came out of storage...
Check the transducer for any damage on the front part. Also make sure there isn't any damage on the bottom of the boat that is causing air bubbles to cross the face of the transducer. If it works at slow speeds there is definitely something causing air bubbles.
May 08, 2010 | Lowrance Lcx 27c 7" Gps Fish Finder Combo...
Radar option
No it will NOT operate radar.
Feb 24, 2010 | Lowrance LCX-27C GPS Receiver
Lowrance LCX-27C has power but only opens to the splash screen then powers down
The LCX-27C will draw up to 1.5 amps when powering up, if that amount of current is now available, it will power down. Double check your power connections. The +12vdc supply must be able to also supply enough current. Once you get it to stay on you can temporarily shut off the transducer by going into full mapping mode, or switch it to sonar simulation and the current draw will drop considerably. When you are ready for the permanent installation run solid connections directly to the battery and be sure to use the inline fuse for protection.
Jul 27, 2009 | Lowrance LCX-27C GPS Receiver
My unit just flashes on the last position that was stored and wa
It may simply be trying to load the almanac and ephemeris from the satellites. This can take up to 1/2 hour with a strong GPS signal outdoors.
Jun 03, 2009 | Lowrance LCX-25c GPS Receiver
Black lines on screen
Are you utilizing another unit in your dash? If so, sometimes when both units are on and in sonar mode, their frequencies will intefere with each other causing the vertical lines. I would suggest turning your dash unit off or lowering it's Hertz rate from 200Hz down to 50Hz.
Funny story...I saw this same issue on my boat years ago. I had an X102C up fron and an LCX-19c in the dash. I acutally thought it was some sort of man-made structure and spent time fishing it...DOH!
Mar 23, 2009 | Eagle Boating
I have a lcx 28c hd fish finding sonar and mapping gps
I've had several similar units, and used them with Navionics HotMaps Premium series chips. You must select Menu. The "Browse files" to access the MMC card option. Once the selection screen opens, choose which card or file you want.
FYI...All of Lowrances HD models come preloaded with pretty much every major lake and river in the US.
Lemme know if this helps...
Triton72
Mar 23, 2009 | Lowrance LCX-27C GPS Receiver
Turning on my Lowrance LCX 111HD fish locator creates static with my ICOM M502 VHF Marine radio.
Hello LJones0455. From your detailed attempts there are few options. Position the transducers one foward one aft. Connect the negitives of the battiers to the boat still route both positive & negitive wiring to all devices. Check the continunity of your transducers include flexing while ohming. Let me know of the results.
Oct 07, 2008 | Boating
Transducer is mounted on a plastic bracket to trolling motor. when trolling motor is turned on, black vertical lines appear on my screen. lowrance x107 cdf
Aug 23, 2008 | Lowrance LMS 332c Mapping Sonar/GPS...
Lowrance LCX-25c GPS Receiver Logo
269 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
