Question about HP Compaq Presario SR2180NX (RK548AA#ABA) PC Desktop
Won't come on
Have vista home operating system, server is att, so had to downloaded McAfee, noticed after downloading, the computer would shut down and restart, for about three days, next morning computer wouldn't startup, screen came up, launch startup repair, did that a number of times and went thru different steps, one was repairing disk errors, welcome came up but after awhile the computer froze, restarted computer this time was able to log on, copied a large number of files to DVD.s ready to shut down for the night had to update McAfee first, this morning same thing couldn't log on, still can't Has any one had this problem, is it the McAfee or somthing else,is there any thing I can do.
thank you
  • 1 more comment
  • charleu Apr 18, 2009
    no viruses, removed Norton and installed McAfee from att web site
  • Kenneth Reaume' May 11, 2010
    Do you have any Symantec software programs such as Norton's on your system?
  • mrninja
    mrninja May 11, 2010
    was Mcafee installed on a clean system? (no viruses)?
  • 184 Answers
Run a full system scan of your computer to see if the download came with a trojan. if nothing is detected. click on start then run and tyoe sfc /scanall to repair any system files that are changed.
Posted on Aug 04, 2009
Mcafee is a very heavy antivirus. try to get rid of it as it seems ur system cant support such a heavy antivirus.
for another antivirus and technical support at cheap rates i would suggest to visit below mentioned link
http://tinyurl.com/m7ghqz
Posted on Jun 20, 2009
    Problem Solver:
  • 5 Answers
I have this machine. Vista 32Bit needs a minimum of 2GB of memory just to run the basics. I was able to get Patriot DDR2-6400 kits of 2MB each stick to install 8GB even though HP supports only 4GB of memory. I used the Low Latency labeled (low density, unbuffered, non-ecc) kits with the tall black heat spreader fins. Frys had them for $70 for the kit of 2 sticks (4GB kit). Forget about salvaging your OS, but since you managed to backup your data, create the restore disks (from the Control Panel) and start from scratch. One suggestion before starting, is to strip your case down and blow out the dust and debris first. Then use a PSU Tester to make sure your power supply is not going to cause you any grief from bad voltage outputs, especially over-voltages. If you test and suspect the original PSU is not right and usually the common problem IS this OEM PSU, then pick up an Enermax 24ATX Pin with atleast 400Watts and dual 12 volt power rails of no less than 16Amps each. Split them between the SATA Drive from the M/B & DVD. Now that the hardware is up to par, your random shut-downs and disk errors should be a thing of the past. That's what I did to fix my same problems on my Presario SR2180NX. Maybe when the faster processors start to go down in price, then I'll install the top of the line to max the speed. Hope some of this helps! -Gregg
Posted on Sep 30, 2009
I can't access McFee protection on my Dell pc. The McAfee icon has disappeared from desk top and the link at the bottom right hand side of screen doesn't work.
The advantage of using McAfee is they have a very good support system. Google 'McAfee support' and take it from there. I have found the live chat with a McAfee to be very good.
Feb 24, 2015 | Dell Computers & Internet
Do i have to shutdown my labtop when finished when i start back up i have to download my mcafee every time why
Shutting down your windows when finished keeps the operational system stable, mcafee should only require a single download, go to www.mcafee.com and contact customer support for answers.
Jun 03, 2012 | Computers & Internet
How to download anti virus
Have you tried doing an online virus scan from Mcafee, Nod32, and other anitvirus companies? There are freescan out there. You can also try downloading Malwarebytes pretty reliable software.
May 05, 2010 | Microsoft Windows Vista Home Premium with...
After installing ie 8 having many problems, had 2 virus now they are gone but computer still giving me many errors. I can't even do a system restore to an earlier date. I had problems with Mcafee not...
IE8 from Microsoft cannot give you viruses. Did you download ie from another site?
This looks like viral activity for real.
Could be coincidence that it happeneed after installing IE 8 whether from MSoft or otherwise.
Delete the ie 8 and do a system restore to a point earlier ...
Dec 18, 2009 | HP Pavilion Media Center a1330n - AMD...
Can't download mcafee
- the reason why you can't download and install Mcafee is because most likely you have a previous installation of it.
- If that's the case, do this steps:
Step 1 - Uninstall your McAfee consumer products using Add/Remove Programs in the Windows Control Panel Windows 2000/XP
  1. Click Start, Settings, Control Panel.
  2. Double-click Add or Remove Programs.
  3. Select the McAfee SecurityCenter product.
  4. Click Remove and follow the steps provided.
Windows Vista
  1. Click Start, Search, type Programs and Features, and click Go.
  2. Double-click Programs and Features.
  4. Click Uninstall and follow the steps provided.
Step 2 - Download and run MCPR.exe
  1. Download the removal tool from: http://download.mcafee.com/products/licensed/cust_support_patches/MCPR.exe
  2. Click Save and save the file to a folder on your computer.
  3. Navigate to the folder where the file was saved.
  4. Make sure all McAfee windows are closed.
  5. Double-click MCPR.exe to run the removal tool.
    NOTE: Windows Vista users must right-click MCPR.exe and select Run as Administrator.
  6. Restart your computer after receiving the message CleanUp Successful.
    Your McAfee product will not be fully removed until the system is restarted.
Nov 02, 2009 | Microsoft Windows XP Home Edition
New computer with vista os keeps locking up while running mcafee virus scan
REmove Mcafee off of the computer and install AVG or Avast both are FREE downloads and FREE antivirus programs. Wont slow the computer down or lock it up
Feb 18, 2009 | Microsoft Windows Vista Home Premium with...
Lexmark X1150 Will not scan or copy
If you are using windows xp home or pro and your scanner will not work and is making a clicking noise when you try to scan. this patch will fix the problem.
Just click on the link and download the patch.
PR1 ALL X1100 EA
Oct 15, 2007 | Lexmark X1150 All-In-One InkJet Printer
HP Compaq Presario SR2180NX (RK548AA#ABA) PC Desktop Logo
99 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
