Question about Ovens
Hi We have an AEG Competence Oven that works and then cuts out. What I mean is that it heats up then the fan and light go off and then come back on later - and so on and so on. We tried to have the mo
Hi We have an AEG Competence Oven that works and then cuts out. What I mean is that it heats up then the fan and light go off and then come back on later - and so on and so on. We tried to have the mother in law around for roast chicken but nearly ended up killing her with food poisoning. It is an AEG Competence oven with no brand number - however it has 3 buttons all in a row underneath the digital display - one is a minus sign, one a clock sign and one a plus sign. There is also a number on the inside of the door which reads PNC 944 181 819. Please help. Thanks
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: aeg competence oven fan not working
If fan has stopped altogether, then you definately need a new one, to be sure you need to disconnect and remove the fan and bench test it.
Hook up a 240v supply to the fan and see if it runs, if not then it is no good..
It does not matter which terminals you connect live and neutral too as it is common to both terminals. do not connect feed to earth by mistake.
Plz leave feedback.
Posted on Dec 09, 2008
barkencoa
  • 3463 Answers
SOURCE: aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Posted on Jan 27, 2009
SOURCE: Oven gets too hot AEG B3101-4
Aeg B3101-4, oven turns itself off and takes 20 minutes to come back on. If put on above 150 it cuts off after a short while
Posted on Sep 20, 2009
barkencoa
  • 3463 Answers
SOURCE: AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Posted on Feb 05, 2010
Competence 5208B, fan oven blows cold and won't heat up, ordinary (non fan) oven does get hot
Hi.
You need to replace the oven element, located at the rear of the oven compartment behind a removeable cover.
Nov 09, 2010 | AEG Ovens
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
May 04, 2010 | AEG B1180-4 Electric Single Oven
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
Hope this helps.
Feb 05, 2010 | AEG Ovens
Oven is AEG Competence, single oven, fan assisted, 4 yrs old. Oven doesn't heat. Light ok, automatic cooking settings not switched on, grill working
If the fan is working o/k, then you need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
This should solve the prob.
Please leave feed back.
Thankyou.
Jan 06, 2010 | AEG Ovens
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 29, 2008 | AEG D5701-4 Electric Double Oven
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Ovens Logo
783 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
