Question about Canon PowerShot S5 IS Digital Camera
Canon S5 IS - problem with the LCD monitor in the closed posit
The camera appears to function ok when the LCD monitor is wide open but when it is moved to about 1cm from the closed position buttons such as FUNC, MENU, & DISP etc and the zoom become inoperable; the mode dial goes out of synch with the display which changes from "auto" to "video".
In other words the camera can not be fully operated with the LCD monitor in the closed position.
    Sergeant:
  • 246 Answers
The LCD hinge defected.
Here is a guide to show you how to replace it.
How to fix an intermittent display LCD on Canon PowerShot S5IS
Posted on Aug 15, 2009
    Novelist:
  • 164 Answers
You camera needs a professional diagnostics and repair service.
The LCD screen assembly has two different position switches, may be one or both are failing (flas contacts internally).
Other possible reason for it is a false contact in the cables and connectors that attach the LCD screen to the main board.
Bottom line, if you have experience and skills in fixing electronic devices, you may want to fix it yourself. otherwise, I do recommend you to have a camera repair technician in fixing your camera.
Best regards,
Posted on Jul 25, 2009
Line appearing in pictures and on lcd screen.
Contact the support guys at the Canon website...Canon may repair your camera at no charge.
Feb 22, 2010 | Canon PowerShot S5 IS Digital Camera
How can I solve an error 99 problem in my Canon Rebel xs
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Aug 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon Powershot S5 IS. Changed to Windows Vista
I have a Canon Powershot S5 IS. Does anyone know the replacement part number of the LCD Monitor?
I am not sure if the the Screens on E-Bay are the right ones. The placement of the 'ribbon' has me second guessing the accuracy of the items for sale.
Jul 18, 2009 | Canon PowerShot S5 IS Digital Camera
In the shooting mode no picture on the LCD monitor
I HAVE CANON POWER SHOT 620 DIGITAL CAMARA. NOW I WAS NOT ABLE TO SEE ANY IMAGE IN LCD MONITOR, LCD BECAME WHITE, TELL ME THE SOLUTION
Jan 30, 2009 | Canon PowerShot A75 Digital Camera
Super macro
Press the macro button once to get it to display the Macro Mode sign. Press and hold it after that to get it into Super Macro
Once you are in Super Macro, you can't move the lens so you MUST use the Manual Focus (MF) button that is located right above the Macro toggle button. While holding the MF button, use the 4 way directional pad to focus in and out. Press the Up and Down to focus.
You have to be REALLY close for Super mode.. less than about 6 inches
Aug 16, 2008 | Canon PowerShot S5 IS Digital Camera
Black LCD screen on canon powershot S5 IS
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Aug 11, 2008 | Canon PowerShot S2 IS Digital Camera
Canon digital G5 LCD monitor problem
Very simple fix. Open the covering on the lcd screen and also remove covering that is between the camera and screen. There is a wire that goes from the lcd screen to the camera. It came out from all the twisting of screen when opening and closing. Carefully put that back in. Google keywords like "lcd g5 fix" etc. for more detailed description.
Jul 20, 2008 | Canon PowerShot G5 Digital Camera
I can't get my Powershot S5 to go into Super Macro mode - Help!
There seem to be two stipulations for getting into super macro mode,
First you must be in scn ("A" or "S" mode's only) and "movie", "P", "TV", "AV" or "M" modes only.
Secondly the zoom Lens must be all the way out.. set at the widest angle.
Best of luck
Jun 14, 2008 | Canon PowerShot S5 IS Digital Camera
Powershot S1 IS trouble shooting in images of lcd monitor
Try playing back pictures you know were captured properly ( either with another properly working camera or with your camera before the problem with quality has appeared ). If the image is ok in playback but 'noisy' in capture mode then the CCD sensor is faulty /on its way out. Ask Canon if they repair CCD faults on this model free of charge.
Aug 18, 2007 | Canon PowerShot S2 IS Digital Camera
Flash Problem
Using the flash When shooting with the built-in flash, open the flash manually. The flash does not pop-up automatically. The flash will not fire if it is closed. The flash will work when it is opened up. When the flash is open, the (flash on) icon or (automatic) icon will appear on the LCD monitor (or in the viewfinder). Flash on: The flash fires in every shot. Automatic: The flash fires automatically. Press the (flash) button to switch between the and flash modes while the flash is open. In some shooting modes, the flash mode does not switch even if the flash button is pressed. Please refer to Functions Available in Each Shooting Mode in the Camera User Guide provided with your camera for more information. When you are not using the flash, close it manually. When the flash is closed, the flash will not fire and the icon appears on the LCD monitor (or in the viewfinder).
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
443 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
