Question about Refrigerators
Refridgerator not working?
For some reason my fridge and freezer have quit running today? Got home from work went to put in groceries and it isn't cool at all?
  • jonathan_112 Apr 18, 2009
    seems as if compresser and fans are on.....do not see a defrost timer? Thanks for your help
  • 121 Answers
Tap on thermostat see if you here fans or compressor
come on or locate defrost timer and advance it
Posted on Apr 17, 2009
  • lojacksdad
    lojacksdad Apr 18, 2009
    if fan and compressor are running and no cold air that would mean coil frozen up or that all the freon is out look on back wall of freezer to see if there is a big ice build up
Hi My fisher payel fridge with the under freezer has a built in ice maker and it has stopped working. What do I need to do to fix it?
Tell me more, why did it suddenly stop? What did you change? Did you turn off electric? Get anything water wise that is new? Did you lower the water pressure coming into your home? Where do you live - house, apartment?
I can't say why it quit, unless you left it running on "make a lot of ice" (some fridges have this option), were out of town and had some electrical issues, went through a big storm or changed the water coming into the fridge. These are the obvious reasons why you'd have an issue.
A little more detail, Please?
Mar 21, 2010 | Fisher and Paykel E522B Stainless Steel...
Freezer cold, refrigerator warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 10, 2009 | Refrigerators
Kenmore Trio: the refridgerator is not getting cool
In the Freezer or Fridge compartment, there is the Evaporator Fan (& Motor) If the freezer is cold, the Evaporator fan motor most likely went bad. Check to see that when the compressor is running, so should be the fan motor. If not, you have to remove it & replace it. It is not an expensive repair unless you call for service on it. Make sure that you unplug the fridge when you replace the fan motor.
Mar 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Refridge compartment warm not cooling
I hope the following helps.
Turn the entire control system off for at least two minutes. This will give the computer module time to reset to factory default. Turn of to desired level after two minutes. Should that not work then there is a problem with the timing relay. They relay is brand specific, meaning take the model number to the parts store for a new one.
Your compressor should be fine. You may also remove the power by unplugging the refrig.
CAUTION: Before removing the relay the power to the fridge must be OFF. Failure to have it in the off postion can cause the new relay to short which can lead to mkore problems. So UNPLUG the fridge, remove the relay, replace the relay and then plug fridge back min. Set control to desired cooling level and wait a couple hours. That should do the trick.. IF not then there is an issue with the processor module.
Jan 04, 2009 | Refrigerators
Refridgerator isn't keeping cold
its in the freezer when you open yhe door the compressor is in the back take the cover off and see if trhe compressor is running
Apr 03, 2008 | Refrigerators
Refridgerator (Bottom Frzr-French Door) not getting cold....Freezer is o.k.
could be a few issues, id open teh freezerdoor at looka t back panel id tere frost building up??? if so youhave a defrost issue, can you here the fan in freezer conmpartment spinning you may have a bad evap fan
Mar 16, 2008 | KitchenAid KBFA20ER Bottom Freezer French...
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
