Question about Honeywell HE365 Humidifier
Water flow from humidifier never stops. Even when furnace is off.
I have a constant drip from my water line that goes into the humidifier. Should it not stop flowing when the furnace is off?
  • 21 Answers
No, it will not stop flowwing if it is the water supply. A solenoid valve opens the flow everytime there is a call for humidity, but it stops at the humidifier when there is no call, so it will leak from that point until it is fixed or tightened.
Posted on Aug 20, 2009
  • Kate Bryant
    Kate Bryant Mar 30, 2014
    should I find a new hose and turn furnace bace on
Aprilaire 700 water never shuts off
the float may be bad or sticking allowing water to run continusly even when unit is off.
Nov 06, 2013 | Aprilaire 700 Humidifier
No water flow through solenoid
The water flow through the humidifier is limited/controlled by an orifice. This small opening can easily clog. After disassembly use a small wire to clear the debris trapped in the small hole,
Hope this helps?
May 18, 2017 | Lennox Healthy Climate HCWB3-17A...
I have a whole house Honeywell E365 humidifier which is constantly flowing water to the pad, even when the heat is not on. What could be the cause ?
Hello, the most common reason this happens is because the solenoid valve is bad and remains open allowing water to flow continously regardless if the furnace is on or off. I assume you have either a sail switch or current sensing relay energizing the humidifier when the heat is on, if not thats another reason it would run continously.
Jan 24, 2011 | Honeywell HE365 Humidifier
Water keeps flowing through my humidifier even when the furnace is not on. Consequently my water bill is quite high. How do I take care of this problem of the water continuously flowing through the unit?
There should be a solinoid valve that starts and stops the flow of the water, based upon a call for heat, and to ensure the fan is running during operation. There must be some failure with this valve, or a short in the connection causing it to run constantly. Hope this helps
Mar 19, 2010 | Humidifiers
Water doesn't shut off completely (drips) when furnace is OFF. Water doesn't increase to a stream when furnace is ON. Also, black connection (regulator ?) between copper water pipe (inlet) and black...
Hi i would check you water line see if they are blocked and checkout the valve and the jet inside where the water goes donw the pad they could be blocked
Feb 11, 2010 | Aprilaire 550 Humidifier
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Water keeps running to Honewell 360A Whole House Humidifier
You may need to replace the valve that is wired to the furnace that controls the water flow
Feb 01, 2009 | Honeywell HE360A1027 Whole House...
Water flow through humidifier
I installed this humidifier (and had a lot of trouble installing it!) and was surprised by the flow of water. Mine leaks out of the bottom of the unit so I haven't actually used it yet. I'll try to figure out why it's leaking this weekend. I thought there would be less water flowing through the pad. I suspect that the weight of the unit is causing it to not be plumb so some water is dripping off of the pad and past the drain tray.
Nov 30, 2007 | Honeywell HE360A1027 Whole House...
Water is constantly filling
Have you checked the position and function of the floats in the pan?
Nov 20, 2007 | Honeywell HE440A1005 Humidifier
Honeywell HE365 Humidifier Logo
665 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
