Question about ASUS A7N8X-E Deluxe : ATX Socket A FSB400 DDR400 AGP8x SATA/RAID Wi-Fi w/audio 2xGb-LAN USB IEEE1394 Motherboard
W3507motherboard front panel connections
HELP! I removed the motherboard from my emachine W3507 to replace the fan with a retro fit and lost track of what configuration the front panel connectors are. (red/white, green/white, black/white). I would really appreciate any help given.
Thank you
Terry B
  • trybker Apr 18, 2009
    Thanks for the info, but this is the wrong manual for my motherboard.Config is different.
    Genius:
  • 1,027 Answers
The manual is Here:
http://dlcdnet.asus.com/pub/ASUS/mb/socka/nforce2/a7n8x-e/e1876_a7n8x-e_deluxe.pdf
However, wires to the case are specified by the case maker (you did not specify). Just about all of them mark the connectors on the wire ends with their functions. Just match with the manual's jumper description.
Posted on Apr 18, 2009
Emachine w3507 powers on but will not boot up
Ram modules might be dirty or dirt in ram sockets
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
hope this helps
Nov 04, 2012 | eMachines W3507 PC Desktop
Does emachines have a parallel hookup for a printer
The eMachines W3507 uses an Intel D102GGC2 motherboard.
Yes it does. It's a DB-25 parallel port.
Look at the I/O area on the back of the desktop computer.
(Input/Output)
The Green PS/2 port is for the Mouse. To the right of it is a parallelogram shaped port.
Pink in color, 13 pins across the top, 12 pins across the bottom.
DB-25 parallel port example, (Not pink in color)
http://en.wikipedia.org/wiki/File:Parallel_computer_printer_port.jpg
Intel Support > D102GGC2 Motherboard Manual download page,
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-022441.htm
Click on the first file listed. English Product Guide [PDF]
(In blue)
This is a PDF file. You may not see anything happening for up to 30 seconds after you click on the file name.
It may also take additional time to fully download.
(Took 4 seconds for the first page to come up just now, and 23 seconds for it to fully download.
Medium speed DSL connection)
Go to Page 11
Oct 22, 2010 | eMachines W3507 PC Desktop
Motherboard power
hey, without seeing it its quite hard, if the cpu fan aint running you have either not connected the cpu fan cable up, or connected it to the wrong place,
are you sure you fitted the cpu the correct way round when you removed it,
and depending on the processor in the computer make sure you aint damaged any of the pins etc on the cpu.
if you can supply some pictures or something can probably help you better
May 28, 2010 | E-Machines eMachines Desktop PC
Emachine w3507 blue light only comes on fan runs nonstop, no signal or monitor, pressing the f8 did nothing
If you get nothing but a blue light and no video at all it sounds like you have a bad power supply. They are easy enough to check and replace but not for a first timer. If you know someone who knows more; get a volt meter and put it on the DC scale. Unplug a power plug to a drive or find one that is not used. Measure the Yellow to black and then the red to black wires. You should get 12 & 5 volts respectively.
Apr 18, 2010 | eMachines W3507 PC Desktop
My niece just called and her emachines w3507 doesn't boot,the light on the front lights and a fan comes on a little louder than normal but nothing else happens,no harddrive light or noise ,screen says no...
start ur computer press F8 rapidly if popup menu came then goto safe mode,if not then u have a problem in ur ram.but u say its giving no signal thats mean vga resolution may be not compatable with ur monitor.go to safe mode and remove ur vga driver and restart ur pc if u have a vga problem.
still u facing a problem then better chage ur ram
Mar 06, 2010 | eMachines W3507 PC Desktop
What motherboad is installed in an Emachine W3507 Desktop PC
The motherboard is a Socket 775 board originally manufactured by Elite Group (better known as ECS). When placed into this E-Machine, very few changes were actually made to the retail version of the 945G-M3 motherboard. This motherboard was built with upgrading in mind. It supports almost every Celeron D, Pentium 4 and Pentium D processor on the market.
Nov 05, 2009 | eMachines W3507 PC Desktop
Fan runs fast all the time
Chances are you need a new fan or it could be your motherboard is overheating so the fan continues to run. Fans are pretty cheap.
or
If you have the expertise to do so, try opening up the unit, detaching the fan and reattaching it. Maybe when you used the air blower it caused it to sit improperly.
Mar 30, 2009 | E-Machines eMachines Desktop PC
No power to emachines t6522
The final set of connections are the front panel leads that attach to the motherboard. This includes the LEDs for hard drive activity and power status, the case speaker, and most importantly, the power switch.
eg:
You should consult your motherboard manual to find out where to plug these in. The power one is obviously the most important.
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | E-Machines (308714) Motherboard
Computer is not working
yes it is ur video card i suggest taking it to computer store
Nov 26, 2008 | E-Machines eMachines Desktop PC
ASUS A7N8X-E Deluxe : ATX Socket A FSB400 DDR400 AGP8x SATA/RAID Wi-Fi w/audio 2xGb-LAN USB IEEE1394 Motherboard Logo
241 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
