Question about Husqvarna Garden
I have a Husqvarna CRT 52 tiller that the gear selector is stuck in forward and will not move. Is this a common problem? It has happened before but came unstuck. It starts and goes forward with no noise just fine, but it just won't change gears. I am wondering if there is something I can do short of splitting the transmission apart. Everything else seems fine.
  • 2712 Answers
SOURCE: crt or srt tiller?
* CRT or SRT -- These are two terms you will see on rear-tine tillers only. o Counter Rotating Tines are best for heavier duty jobs and for breaking new ground. o Standard Rotating Tines are good for aerating the soil and help propel the tiller forward.
Posted on Aug 27, 2008
  • 708 Answers
SOURCE: Transmission is stuck in neural.
Possibly just linkage problem.
Posted on Mar 28, 2009
  • 61 Answers
SOURCE: sprinter gear selector
This is the gear linkages. It is a cable operated system to allow the gear lever to be dash mounted.
They are a common fault. The parts are about £65 from Mercedes (dealer only part) and unless you know what you are doing you can expect about 2 - 3 hours labour charge, though there are no special tools involved.
They average about 60,000 miles, though the replacements tend to be better.
  • 33 Answers
SOURCE: husqvarna yth1842xp 2005 ride on mower won't move in gear
your linkage came apart from the way it sounds. most all these riding lawn mowers are simple machines. you need to fallow the(flopppy lever) and see where it go's it is supposed to attach to a rod or cable and must have came unhooked
Posted on May 02, 2009
  • 86 Answers
SOURCE: Rototiller won't engage into gear
You will need to split the gear case if iam not mistaken it has chain drine the chain links break and you have to replace them
Posted on May 13, 2009
I have a hasquvarna 650 rtt tiller . The gear shifter shaft is seized . The transmission itself is fine it's the shaft going through the tranny body itself that's seized.
This shaft runs into the gearbox selector, it may be an issue with the selector and not the shaft, if so it would need the gearbox splitting, either way it may still need splitting,so you may as well douse with penetrating oil and try to move the shaft with a pair of grips, always worth a try.
Apr 29, 2018 | Husqvarna Garden
Gear box is stuck in netural on my Husqvarna DRT900H. Tiller only 2 years old
This machine has a crash gearbox, if it id stuck in neutral then something has happened to the selector shaft in the gearbox, unfortunatly the box will have to come apart, there is no external adjustment just make sure the arm is tight that connects to the gear change rod.
Oct 03, 2017 | Husqvarna Garden
The tines are not moving forward on my Rotavator. The engine is Tecumsah Vantage 50. The tines move backwards and the engine seems fine. The rotavator will not move forward
I have seen a number of domestic rotavators but haven't yet seen one with a reverse gear. You didn't make it clear in your description whether yours has a reverse gear and that is all that is working or whether it usually only moves forward but is moving backwards?
While it is theoretically possible for a 2-stroke engine to run backwards, your engine is a 4-stroke that is incapable of running backwards and so it would seem the gear selector is stuck if it has one or someone has carried out repair work and made a mistake or something else is broken.
The only thing that comes to mind is some of the older designs used an over-long drive belt that crossed in the middle like a figure eight in order to reverse the driven pulley and replaced the belt with one that seemed the right size would cause the machine to run backwards.
More information needed, perhaps...
Jul 24, 2016 | Garden
Citroen jumper gear change
Your description makes me remember an old Austin Metropolitan I had once. The gear linkage was crude and it was possible sometimes to engage two gears at once resulting in a lock-up and a stalled engine. It never happened while driving at speed.
When repairing a gearbox, once the selector linkage has been removed it is usual to select two gears in order to lock the shafts for the tightening or loosening of a retaining nut. There is built into the internal selector linkage an interlock to prevent two gears being selected.
I imagine that interlock in your gearbox is worn or broken...
Jul 30, 2017 | Cars & Trucks
Husqvarna CRT 650 Tiller gearbox is locked up
first check the linkage rods make sure that its not in forward and reverse at the same time if not you need to open it up to find the problem
Jul 25, 2012 | Garden
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
Husqvarna 700DRT won't change gears
hello, you need parts or a whole new trans,and try and not het any more rocks,,
Feb 11, 2012 | Garden
Ford galaxy 2002 manual. Stuck in a forward gear although cables and linkage seems to be doing its bit. gearstick seems to be changing gear but nothing happening in box
their are three shafts and one of them is the fixing that holds the shaft to the gearbox and this one has most likely broke allowing the others to move but ?? not the selector shaft
Apr 05, 2010 | 2004 Ford Fusion
My Yardsman Snowthrower will not move when it is put in gear.
My old machine just did the same thing. When I lift the unit off the wheels with the gear engaged the wheels move. when I put it down the machine doesn't move. This happened while I was using the machine. BTW the machine is 20 years old.
Dec 31, 2009 | Mtd Products Yard Machines 158CC Tiller
Mar 28, 2009 | Husqvarna Garden
Garden Logo
503 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
