Question about Toro Lawn Mower With Toro Power Tools
Belt routing diagram for 56145 model toro rear engine rider for tension belt, where can I find free online diagrahm? year 1987
2 Suggested Answers
USMC ETECH
  • 60 Answers
SOURCE: have a toro 217d 1986 model with a 30562 62inch
THIS IS THE WEBSITE FOR THE MANUAL. SO FAR THIS IS THE ONLY SITE I HAVE FOUND WITH THE INFORMATION.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#manualsResultPage
I HOPE THIS HELPS IF NOT PLEASE LET ME KNOW AND I WILL FIND SOMETHING BETTER.
Posted on Feb 23, 2010
Belt diagram
HOPE THIS HELPS.. http://www.toro.com/en-us/parts/Pages/PartsDetails.aspx?mybeid=34870&serialNumber=310000001&modelNumber=74366&searchTerm=9lzIRv+p5zeMaPWIo2YCaldb2KV6U4WnyxmRpPSpeQehTowzmaCEK/baRX71tPfJ&defaultTab=parts
Apr 23, 2014 | Toro Zero Turn Rider 74366 Lawn Mower...
Serpintine Belt Routing
Check this on Model GRAND AM, Engine V6 3.1L 189ci GAS FI N M...
Hope helps.
Mar 30, 2012 | 1995 Pontiac Grand Am
Serpentine belt diagram for a 2003 Chevy unpalatable 4.3
Pop the hood of the car and locate the serpentine belt routing diagram. The diagram on the 2003 Chevrolet Impala is on top of the fan shroud. The diagram will be a picture of all of the accessory pulleys and how the serpentine belt is routed among the pulleys. This diagram will give you the exact direction for routing the new belt onto the pulleys. If you cannot find a serpentine belt routing diagram, take a notepad and pen and draw out the exact routing diagram of the old belt across the pulleys.
  • 2 Locate the serpentine belt tensioner. It is located below the alternator on the left front side of the engine. The tensioner on the 3.4 liter, 3.5 liter and the 3.9 liter engines will require a 3/8 ratchet to release the belt tensioner. The 3.8 liter engine will require a ratchet and a 15 mm socket for the belt tensioner. Rotate the belt tensioner clockwise to loosen and remove the belt from the belt tensioner pulley.
  • 3 Slide the old belt from the belt tensioner pulley. Remove the belt from the remaining pulleys and pull the belt from the engine compartment.
  • 4 Route the new belt across the crankshaft pulley first. The crankshaft pulley is the big pulley on the bottom of the engine in the center. Then route the serpentine belt across the remaining pulleys as directed by the serpentine belt routing diagram. Leave the belt tensioner pulley for last.
  • 5 Rotate the belt tensioner clockwise again to relieve the tension and slide the new belt across the top of the belt tensioner pulley. Release the belt tensioner and the belt will tighten up as the tensioner applies pressure to the belt. Make sure the new belt is properly seated in all the pulleys.
  • 6 Crank the engine and inspect the belt again to make sure that it stays seated in the pulleys.
  • Read more: How to Replace a Serpentine Belt on a 2003 Chevrolet Impala ' eHow.co.uk http://www.ehow.co.uk/how_6120665_replace-belt-2003-chevrolet-impala.html#ixzz1Yi6QLAjb
    Sep 21, 2011 | 2003 Chevrolet Impala
    Drive belt routing diagram w reg ford focus
    Somewhere under the hood, usually on the fan shroud or near the radiator, there should be a sticker with a diagram of the belt routing, 2001 may even be on the hood. On this diagram it will show a tensioner pulley and idler pulley and the approximate location. Most Fords use a 15mm or 16mm bolt on the tensioner, this is where you put a wrench to rotate the tensioner and remove the belt. When you turn the tensioner bolt turn towards the front of the car, there will be a lot of tension so pull hard.
    Also Dayco.com offers a free online comprehensive serpentine belt reference tool - including routing diagrams and tensioner information.
    Jun 18, 2011 | Ford Focus Cars & Trucks
    How to change the serpentine belt. a diagraham
    Welcome to Fixya
    Here's the procedure on how to replace the serpentine belt. I am sorry if cannot provide you the diagram.
    1. Open the hood and locate the serpentine belt routing diagram. The diagram is on a sticker originally adhered to the fan shroud or the underside of the hood for easy referral when replacing the belt. If the sticker is no longer on the Pontiac, you'll need to get one either from your local Pontiac dealer, in the Pontiac's specific service manual or online. Or you can draw a diagram of your Pontiac's pulleys and belt, showing how the belt routes around the pulleys.
  • 2 Insert the tip of the belt tensioner tool into the corresponding notch on the serpentine belt tensioner. You can locate the tensioner by looking for a pulley located at the end of an arm. This arm and pulley assembly is the tensioner.
  • 3 Pry the tensioner arm away from the belt face with the tensioner tool. On some Pontiacs you can substitute a large socket wrench, but the risk of damage to the tensioner increases greatly with the socket wrench. The price of a tensioner tool is far less than that of a new tensioner, so avoid the socket wrench and buy the proper tool at your local auto parts store.
  • 4 Push the belt off the tensioner pulley with your free hand and slowly move the tensioner back to its relaxed position. Pull the tool out of the tensioner and set it aside for now.
  • 5 Pull the belt off all the pulleys and lift it up out of the engine well. Depending on the year, make and model of Pontiac you are working on, you made need to access the lower pulleys from below the engine well or through the wheel well to get the belt out.
  • 6 Stretch both belts out to full length to make sure the new belt and old belt are nearly identical in length. The new belt should measure less than an inch shorter than the old one. This is due to some stretching the old belt received during its lifespan.
  • 7 Route the new belt around the pulleys, beginning with the crank pulley and working your way up until the tensioner pulley is the only one left. Make sure to consult the routing diagram frequently during this step. If you route it improperly, you will have to either take it off and start over, replace whatever component this damages from the improper routing, or seek first aid for the injuries you suffer.
  • 8 Plug the tensioner tool back into the tensioner body and lever the tensioner pulley away from the belt path once more. Pull the belt over the tensioner pulley and hold it there with your other hand as you slowly release pressure on the tensioner. Take the tool out when done.
  • Thank you for using Fixya!
    Dec 08, 2010 | 2005 Pontiac Bonneville
    Belt diagram on 2002 ford taruas 3.0
    Nov 20, 2010 | Ford Taurus Cars & Trucks
    I need to know how to remove an A/C compressor pulley on a 2000 Mazda B3000, in order to route a new surpentine belt.
    3.0L And 4.0L Engines
    1. Disconnect the negative battery cable.
    2. With the vehicle in neutral, position it on a hoist.
    3. Remove the splash shield.
    4. Rotate the accessory drive belt tensioner clockwise for 2001-2004 models and counterclockwise for 2005-2006 models. Remove the belt.
    5. To install, reverse the removal procedure.
    Serpentine Belt
    All Navajo and B Series Pick-up engines utilize one wide-ribbed V-belt to drive the engine accessories such as the water pump, alternator, air conditioner compressor, air pump, etc. Because this belt uses a spring loaded tensioner for adjustment, belt replacement tends to be somewhat easier than on engines where accessories are pivoted and bolted in place for tension adjustment, such as the MPV. Basically, all belt replacement involves is to pivot the tensioner to loosen the belt, then slide the belt off of the pulleys. The two most important points are to pay CLOSE attention to the proper belt routing (since serpentine belts tend to be "snaked" all different ways through the pulleys) and to make sure the V-ribs are properly seated in all the pulleys.
    Fig. Belt routing diagram-3.0L engines
    Fig. Belt routing diagram-4.0L engines
    Although belt routing diagrams have been included in this section, the first places you should check for proper belt routing are the labels in your engine compartment. These should include a belt routing diagram which may reflect changes made during a production run.
    1. Disconnect the negative battery cable for safety. This will help assure that no one mistakenly cranks the engine over with your hands between the pulleys.
    Take a good look at the installed belt and make a note of the routing. Before removing the belt, make sure the routing matches that of the belt routing diagrams. If for some reason a diagram does not match (you may not have the original engine or it may have been modified,) carefully note the changes on a piece of paper.
    1. For tensioners equipped with a 1 / 2 inch square hole, insert the drive end of a large breaker bar into the hole. Use the breaker bar to pivot the tensioner away from the drive belt. For tensioners not equipped with this hole, use the proper-sized socket and breaker bar (or a large handled wrench) on the tensioner idler pulley center bolt to pivot the tensioner away from the belt. This will loosen the belt sufficiently that it can be pulled off of one or more of the pulleys. It is usually easiest to carefully pull the belt out from underneath the tensioner pulley itself.
    1. Once the belt is off one of the pulleys, gently pivot the tensioner back into position. DO NOT allow the tensioner to snap back, as this could damage the tensioners internal parts.
    2. Now finish removing the belt from the other pulleys and remove it from the engine.
    To install:
    1. While referring to the proper routing diagram (which you identified earlier), begin to route the belt over the pulleys, leaving whichever pulley you first released it from for last.
    2. Once the belt is mostly in place, carefully pivot the tensioner and position the belt over the final pulley. As you begin to allow the tensioner back into contact with the belt, run your hand around the pulleys and make sure the belt is properly seated in the ribs. If not, release the tension and seat the belt.
    3. Once the belt is installed, take another look at all the pulleys to double check your installation.
    4. Connect the negative battery cable, then start and run the engine to check belt operation.
    5. Once the engine has reached normal operating temperature, turn the ignition OFF and check that the belt tensioner arrow is within the proper adjustment range.
    Hope helps (remember rated and comment this).
    Sep 07, 2010 | Mazda B3000 Cars & Trucks
    Need belt diagram for toro 56145 serial 7010188
    Go to www.partstree.com. Put your information in and will show you parts list and diagrams you are looking for this mower.
    Good Day.
    Oct 12, 2009 | Toro Lawn Mower With Toro Power Tools
    Belt diagrahm
    Go to repairclinic.com and click on the "Repair Help" link. On the following page, locate the "Dryer Belt Diagrams" link under the Special Features section. Refer to diagrams H, B or K. If you need assistance in determining which diagram you need, post back with your model number and I can assist you better. I hope this helps you.
    Jul 23, 2009 | Kenmore 73952 Gas Dryer
    Toro Lawn Mower With Toro Power Tools Logo
    909 people viewed this question
    Top Toro Garden Experts
    Joseph Mueller
    Joseph Mueller
    Mike Squire
    Roland W VanLue
    Roland W VanLue
    Are you a Toro Garden Expert? Answer questions, earn points and help others
