I need instructions to install this stacking kit
I just bought a stacking kit for a samsung washer model #WF/J1254/XAC and dryer, model # DV665JW/XAC. The guy at the store showed me the washer and dryer and there were screw holes on the top of the washer for the stacking kit. When I opened my washer there are no holes on top for the staking kit. Do I drill the holes myself? Please help
SOURCE: Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Posted on Jun 30, 2008
SOURCE: Detergent drawer
I ended up having to call Samsung support for this same question. Left to right two vertical bars = detergent (liquid or Powder) flower = softner, single vertical bar = bleach.
Posted on Nov 11, 2008
  • 54 Answers
SOURCE: ma samsung wf j1254 is not stable, i leveled many times before
It could be. The front feet have to be manually adjusted but the rear feet are self leveling. If the wood is giving enough to allow the frame to touch ground then it could cause a leveling problem. The front feet are made of plastic on the newer machines if the plastic foot is stripped out, it could be allowing the machine to become un-level during operation.
Posted on Feb 23, 2009
SOURCE: how to stack instructions
I just bought one of these, and the install is pretty simple.
you have 3 pieces, 2 of them go on the sides, 1 goes across the front.
you lay the side pieces on top of the washer so that the little tabe are sticking up,  the end that has 2 tabs and a hole for the screw goes at the back.  once they are laid in place, you put 1 screwn in each piece on the back of the washer (there are holes in the washer for this already) then you put the dryer on to so that the little tabs that stick up kind of hold the feet.
you put the front bar on last so that it's tabs hold onto the front feet, then you screw both ends of the front bar into the side bars.
Posted on Apr 23, 2009
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
Sep 13, 2014 | Bosch Axxis WTA 3510 Electric Dryer
No heat model dv665jw/xac
Element or thermal trip on element, you will need to test them with a meter, as to which one, But if thermal trip gone, why, could be element on way out.
Mar 18, 2013 | Samsung 7.3 Cu. Ft. Electric Dryer
SAMSUNG WF-J1254 washer very shaky when it's spinning, Help.
machine must be level there are 4 adjustable legs (1 in each corner) place a level on machine , level left to right and front to back.also check manual for initial set up there may be shipping screws that need to be removed on the back of the washer. good luck
Jun 11, 2012 | Samsung 3.7 Cu. Ft. Stackable Front-Load...
Hi, I have problems with SAMSUNG Dryer Model # DV665JW/XAC. It does not dry clothes at all. Could u please help!!! cheers, lucina
you probably have a broken wire in the heating element. located on the back of machine, top right corner, behind panel.
remove the two screws
Sep 01, 2010 | Samsung Dryers
Can't locate stacking kit for HE2 Plus Washer and HE2 Dryer
more of the model number would help, but i can get them parts for you at www.whirlpoolpartssurplus.com feel free to give us a call
Jun 23, 2009 | Kenmore HE2 Plus Front Load Washer
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
486 people viewed this question
Top Washing Machines Experts
