Question about Dryers
I have a fixer upper house and put in a vinyl dryer vent to the outside and now i am told that it has to be metal. I have vinyl siding. Does it really have to be metal? where can I find Laws verses guidelines that are mearly suggestions or recommendations that do or donot hae to be followed to. the letter. john
    President:
  • 331 Answers
JD,
Please follow this link and read it carefully. Dryer ventilation is a serious, serious business (safety-wise). I know you don't want to turn your fixer-upper into a pile of ashes.
Here's another link to help you (many of the links on this page are no longer available, but the text of the article still applies).
Another good read (specifically, the "outside the dryer" article)
Or simply click this link for all the info you could ever want.
Seriously, think long and hard, weigh the risks vs. the short term $$ savings.
SG
Posted on Apr 18, 2009
  • 371 Answers
You can find these "guidelines" at your local municipality's or county's building department.
Psst: Don't go there, just take the suggestion and replace the vent with metal, which will last longer than
the vinyl, and can be painted, if you wish, with vinyl paint to match your siding.
PS: Don't go to the zoning board or building department or you will have to thank me after much expense.
Posted on Apr 17, 2009
I have an lg 5988 dryer, only will stay heating on delicate cycle. any other cycle I have to reset, by pushing the button on the sensor on the exhaust inside back of dryer. I replaced that sensor 3 ti
Sounds like a airflow problem. Either the House vent is clogged or some major build up in the blower or lint housing.
Remove the vent hose from the dryer and see how well it is blowing, then reconnect the vent and check outside, it should be close to the same.
House vent should be short and strait as possible, and metal venting only.
Dec 27, 2014 | LG DLG5988 Gas Dryer
Hotpoint tcem80c 6p not drying very quickly
Long Dry times tend to be caused by improper exhaust venting
normal ventng should be 8 to 10 feet long max should be flexible aluminum or solid metal venting if length is longer than 10 ft solid metal venting is a must ! White Vinyl is absolutley NOT advised ! ! make sure venting is as short as possble with no kinks or crushed areas and also you have good air flow out of dryer exhast outlet before connecting venting after connecting make sure you have good air flow at outside of home.........good luck !
Jun 21, 2014 | Hotpoint TCEM 80C 6P White Electric Dryer...
How should the dryer vent be in stalled they have taped it and it falls off the vent is the same size and the housing under the dryer shouldn't they dryer vent piping be a little larger so that is goes...
if its a solid piece you can take a set of sheet metal snips and cut some 3/4 to 1 inch slices down the tube end and continue around the pipe at about 1 inch intervals, this will allow you to ease the pipe over the venting from the dryer and also over the vent cap leading to the outside, then use metal tape ( not screws, they tend to grab lint on its way out ) to cover the splices, I always use a 4" hose clamp on mine to ensure they stay on and in place
Jul 06, 2011 | Dryers
My ler4634eqo throws heat but takes 1 1/2 to dry cothes
before you look at the dryer , check your venting. 80% of all our dryer calls are a result of poor airflow. Vent connector between dryer and main vent or outside wall should be 4" rigid metal or heavy metal flex. Dryer manufacturers consider plastic, vinyl and foil to be improper due to their tendency to crimp and flatten easily. Vent coluld also be stopped up.
Check outside exhaust opening to be sure it is not clogged or otherwise closed. Best way to check vent sometimes is to pull dryer out, remove vent and run a load of clothes. If drying time is significantly better, then venting is your problem.
Whirlpool sells a heavy metal flex vent kit , part #4396028
Dec 28, 2010 | Whirlpool Dryers
The heat goes on temporarily and then shuts off
The most common problem is a clogged vent.
To do this, unplug your dryer and move the dryer out enough so you can get to the dryer duct easily. Most dryer ducting is flexible like a big slinky with a vinyl(older style no longer used) or metal type covering. There are some that are rigid as well.
Remove the duct from the dryer and where it attaches to the wall. Use a shop vac or house vac with attachments and insert through the wall and vacuum as much as you can. I use a shop vac since it has the blowing capability and I can check if air is coming out of the dryer vent located outside after I vacuumed it out. It is good to get confirmation that air is coming out of the vent. Check the dryer where the duct was attached and vacuum anything that is in there. Put everything back in reverse order and give it a whirl.
There are some homes,condos,and apts the have the hidden ducting go up the wall and through the roof. If this is the case, you will need to go on top of the roof and find the vent pipe. This pipe will have some sort of cap on it to let the hot air out but keep other elements out. Since you mentioned the heat goes on for a bit, have someone go on the roof (use caution) and have someone else turn on the dryer. The person on the roof can check the vent pipes with his hand for heat.
Nov 16, 2010 | Whirlpool Dryers
So I emptied the lint trap as I always do before putting in more laundry and start the dryer. When the dryer stopped the lint trapped was overflowing into the dryer. I emptied it and restarted the dryer...
This sounds like you have a blockage in the dryer vent tube. This is the plastic or metal exhaust tube the exits the dryer either in the back or the side. If you know where the vent exits the house you can go outside and with the dryer on you should be able to feel warm air exiting the vent. You might also look to see if a animal has made a next in the outside vent. You may also need to remove the exhaust vent from the back of the dryer, Generally it's connected with a few screws or a ty strap. Once the vent is removed you will physically need to look in the vent to see any obstructions. Remove anything you find. Once again start the dryer on no heat mode if you have on or on low heat and feel if you have any air coming from the vent with the hose or tube removed from the back. If no you have a good air flow then you have cleared the vent, no reconnect the vent tube and recheck back outside. You should have air flow through the outside vent, if not you will need to remove the vent obstruction. If you find that you have no air flow and the dryer drum is turning then you have a broken blower wheel.
Jul 08, 2010 | Maytag PYE2300AY Electric Dryer
My dryer comes on and spins, but it is not drying the clothes. What could be wrong?
Its most like to be the thermostat, temp sensor or the heating element is broken.
Sep 10, 2009 | Hotpoint Dryers
Dryer vent filled with water. Large loads would not dry.
If the drying problem is caused by poor venting/air circulation, then things probably won't improve until that situation is remedied. Check out the link I am attaching. It contains dryer venting requirements. Hope this helped and I'm sorry for your trouble. Best wishes.
http://www.mediafire.com/?4yazrf2jz3d
Sep 07, 2009 | Dryers
Need to side vent LG dryer
if you have an opening on the side then yes you can shorten the stiff tube that comes out the back but i recommend you get a stiff elbow to make the turn and add whatever is needed to come out the side then attach the flexible to the wall. that's the safe way of doing it. That air is pretty hot in the cabinet
Mar 01, 2009 | LG DLE5977 Electric Dryer
Kenmore model 110.64672400
Yes if it taking long to dry the vent is still resticted. Thats all it can be! Nothings wrong with your dryer! focus on the vent and you will fix it!
Dec 01, 2007 | Kenmore 63942 Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
