Question about Toshiba Satellite U205 Notebook
Hard Disk Sound
My Notebook (Toshiba Satellite U205-s5057) is only a month and half old .. and the hard drive is making some noise while reading or writing some data. Any suggestion.. should i go and claim the warranty?
A little noise is normal while the HDD is working. Use the warranty if it is too loud.Extra loud is usally a sign of failing HDD.
Posted on Sep 17, 2007
Satellite u205-s5057 freezes up when online.
Sounds like a bug. Download and install CCleaner and Malewarebytes from CNET. Run CCleaner first, both the Cleaner and Registry, then Malewarebytes on a Quick Scan. If there is a Java or Adobe Flash bug in the laptop, Malewarebytes will find them.
Your not done yet!
Download TDSSKiller for Kaspersky. You can find it on Google and at CNET. Run TDSSkiller and make sure there are no root kits. When you are done with that, make sure you have all your Microsoft, Java and Adobe Updates then Run a Full Scan with Malewarebytes.
Please post how this works out for you.
Jan 18, 2014 | Toshiba Satellite U205-S5057 Laptop AC...
Toshiba u205 - SD card won't stay in reader
Just buy an external SD card reader that plugs into one of your usb ports. You should be able to get one at any local pc shop or best buy.
Aug 17, 2012 | Toshiba Satellite U205-S5057 Laptop DC Car...
Toshiba U205-S5002. From PC to inverter is 9 pins. What U is on this pins? Thanks.
I was install the os window7 for new ssd in my laptop but unfortunatly was not install and reback my old hard drive install but then after i turn on the laptop but screen was not start.
Dec 22, 2010 | Toshiba Satellite U205-S5002 Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          Hard drive
          These instructions should help.
          Toshiba® Satellite 100, 105, 110, 115, 200, 205, 210, 400, 405, 410, 420, 430 Series
          Hard Drive Installation Instructions
          1. Turn notebook upside-down.
          2. Remove the battery compartment cover.
          3. Remove the battery pack.
          4. Remove the 2 Phillips screws that mount the hard drive down.
          5. Slide the hard drive away from its connector and gently lift it out of the notebook.
          6. Remove the tray from the old hard drive and assemble it onto the new hard drive.
          7. Slide the new hard drive into its connector inside the notebook.
          8. Replace the 2 Phillips screws used to mount the hard drive into place.
          9. Replace the battery pack.
          10. Replace the battery compartment cover.
          Jul 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
          Hard drive
          I think as bigger drive as ya can afford say up to 80GB.. would be OK.. just make sure that the new drive is same type as old and ya be all good.
          Jul 28, 2008 | Toshiba Satellite A105 Notebook
          How to install toshiba satellite u205-s5057 memory
          There is an access panel on the bottom of the laptop remove that and just insert the stick of ram. Make sure that you are grounded when holding the ram as you can shock it with static electricity.
          If you need further assistance don't hesitate.
          Thank you,
          Lee
          Jun 18, 2008 | Toshiba Computers & Internet
          I need to replace my hard disk notebook with a bigger capacity hdd
          Toshiba is rather secretive with their documentation. It is hard to find. Google TOSHIBA SATELLITE A10 SERVICE MANUAL and check the available offerings.
          You now have a 5400 RPM, ATA 100 drive. You should not have any drive size restrictions. Shops are advertising many large drives as compatible.
          I suggest that you purchase only a 7200 RPM drive. The faster speed will perk your machine right up.
          I have not worked on Toshiba machines but suggest you have all restore disks and passwords at hand.
          Feb 18, 2008 | Toshiba Satellite A10 Notebook
          Toshiba Satellite U205 Notebook Logo
          248 people viewed this question
          Top Toshiba Computers & Internet Experts
          pankaj rautela
          pankaj rautela
          Alun Cox
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
