Question about Black & Decker Saws
Trigger Switch needed.
I am looking for a Trigger Switch for my B-D 7390 Type 4 circular saw.
Part number 380779-00
The few websites I have found say the trigger is discontinued… I can’t believe this trigger switch doesn’t exist somewhere!
Any help would be great!
Thanks
  • David Ford
    David Ford May 11, 2010
    Are there any names or numbers on that old switch, I was goofing off and came up with another idea. Let me know
  • David Ford
    I have struck out on 6 different sites, so my next best solution is if you have a repair facility in your area take the switch and see if they can match it up with someone elses switch. Good luck and sorry I don't have better news
rowdy45176
  • 2176 Answers
SOURCE: i need a wiring diagram for a milwaukee heav duty circular saw
It is probably something like a 6365 and on all the Milwaukee products they have a switch wiring diagram but nothing for the switch. I would recommend going to a local repair center with the switch and match it up with a new one probably less than 15.00 If you give me your location with zip code I can direct you to the closest one. Let me know
Posted on Apr 14, 2009
  • 25 Answers
SOURCE: dewalt power saw wiring diagram for trigger switch
The Switching should go like this
(single letters denote wire color)
Y---o o---R
B---o o---B
The contacts where the black wires attach are the points on the switch that break when continuity is checked.
Posted on Apr 18, 2009
  • 16 Answers
SOURCE: The triggerj switch is malfunctioning in my 10
Contact Ryobi via their website and ask for details of a supplier near you. Ryobi are very good with parts for older models.
Posted on Jul 07, 2009
  • 384 Answers
SOURCE: craftsman radial arm miter saw parts discontinued
Any hardware or home improvement store will have a replacement.
Posted on Jul 22, 2009
brewerstool
  • 141 Answers
SOURCE: dewalt saw does not work
You more than likely have a break in the field. In order to test this you will have to take the field out of the motor. There will be 4 terminals on one end of the field. Test between 2 terminals of one side of the field. You should have continuity. Then test the other side. (By side I mean the windings will be seperated one on each side.) The most common problem with these saws is that the field wire at the terminal comes loose from overheating. You may be able to scratch the wire up a little (because it has epoxy on it) and then solder it back to the terminal. (Originally the wire is pressed into a slot in the terminal, but this will be broken, so you will have to solder it for it to make contact and stay) It will save you some money from having to buy a new field. Eventually though you will have to replace the field and make sure that there isn't a running short between the field and armature that caused the overheating in the first place.
Posted on Oct 13, 2009
Need parts for Black and Decker circular saw model 7390
Go to
http://www.ereplacementparts.com/black-and-decker-7390-type-circular-saw-parts-c-4167_4252_12157.html
Jan 24, 2013 | BLACK and DECKER POWER TOOLS Black And...
I have a Sears Craftsman 71/4 " circular saw, model number is; 31510864 which is no longer supported by Sears. My trigger (on/off) switch has gone bad and am looking for the part number and hope...
I don't know if this will help you but I have found in the past that craftsman and black & decker small power tools used the same switches. Hope this helps you. Thanks
May 17, 2011 | Garden
First time using, plugged in, power light/laser works. Saw will not turn when pressing trigger.
Same problem with mine but I.found a guy's blog on google and he had identical problem and found the "pre travelicon1.png switch," that they saw fit to put in the saw was the culprit. It's not a typical switch and has issues making contact often times (Ryobi are you listening?) He was able to take it apart and make a adj/repair (instructions he provides on blog) but who knows how long it will last? Here's the link:)-> http://www.woodtalkonline.com/topic/9508-ryobi-circular-saw-broken-and-fixed/
Feb 26, 2011 | Ryobi 7 1/4 In. Circular Saw W/ Dual...
I just purchased your Mod 5740NB circular saw. I have used it a few times and now the on off switch does not work. If you plug it in it runs and will not respond to the trigger. I own a lot of Mikita tools...
I have three of these saws and have had the same experience but only after hundreds of uses and it's kinda expected. Since this is a relatively new saw try (with it unplugged) pull the trigger and slide your finger to the side allowing it to snap back. Try this a few times if you do need to replace the switch, order the part and do it yourself, if you can operate a saw and you still have all the at the end of the day, this should be a job you can handle. If it's still under warranty you'll have to send it in.
Oct 09, 2010 | Makita 7 1/4" Circular Saw 5007NB
I have an old Craftsman circular saw that needs a new switch ( Model 315.27802), part number is 2-622659-01. It appears that Sears no lomger carries the part. The saw is still good. Can another brand of...
It will probably be tough to find a dead one around with a good switch.You could rig a switch to it if you wanted to.Bring the old one with you and go looking for something similar.Is it a trigger switch?That would be very tough.If it is a regular on/off switch,slide type,there may be power ratings requirements so that the switch doesn't burn out.Let me know if you need help determining a power rating.Good luck! Greg
Aug 13, 2010 | Saws
As soon as i plug my circular saw it turn on, what can it be?
the switch is stuck in the on position, take a look for wood jammed under the trigger and it nothing found you would need to replace the switch.
Jun 28, 2010 | Ryobi Circular Saw W/Dual Laser
I have an older sears cicularsaw model 31511850 i need a switch but it is no longer available where do i look?
The trigger operated switch should be available if you look at the switch itself and read the numbers off of it and find it on the web, its a pain but it beats buying a new saw because a cheap switch failed.
Jun 17, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
I have a 7 1/4 milwaukee circular saw.It won't start up.I've replaced brushes but won't start.What could be the problem?
Could be quite a few, what is the model number. Do you have a volt ohms meter, if so check the cord first (UNPLUG) and across the switch then lock the switch on and check the brush holder leads. If you loose continuity anywhere in this process that is probably the problem. What did the brushes look like, did the mating surface look smooth or burnt. Let me know and I will try and help also give me the model number and brand, the header has 2 listed.
Jul 10, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
How to wire switch for Dewalt DW718 Type 1 mitre saw.
Does the switch not have color words on the back of it? They used to. Go to Dewaltservicenet.com and look up your model number and type number. Wiring diagrams will be found there. Lemme know. Please rate me
Jun 17, 2009 | Saws
Saws Logo
190 people viewed this question
Top Black & Decker Saws Experts
Ruben Bustamante
Jason
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
