Question about Pioneer VSX-818V-K Receiver
Poineer vsx-810s amplifier
It turns on then power offf comes on the dsplay flashes 3 times then goes off tahts is with no connections to amp
  • 4 Answers
If it flashes AMP_ERR, one of the chipamps is shorted & needs to be replaced.
Posted on Aug 12, 2009
Poineer deck amplifier dc-z74 relays click but set deck does not come on no display lights dead unit
Part of your PowerSupply is Frito.
Probably the +/- 15 volt rails, could be other.
Check inside power voltages, probably some regulators are gone.
Preferably get a tech unless you have the know-how and test equipment...
PEACE---
Feb 09, 2016 | Audio Players & Recorders
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
The power does not turn on no matter what outlet I plug it into. When I first turned it on Amp Err plashed on the screen and it clicked and shut off.
The amplifier shuts down as a protection to prevent further damage.
Most of the times it means one of the power amplifiers has malfunctioned and is causing a short.
If you have nothing connected to the speaker terminals when it's doing this you should have it repaired.
if you do have speakers connected try disconnecting them.
Dec 21, 2010 | Pioneer VSX-52TX Receiver
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
I had only static on back speaker of pioneer vsx-d810s. Now I can not get the back speaker to work at all. Tried every step in the manual ten times. Now I can not turn DTS on or off. Monitor only show...
well you must config the surrond back speaker , check in operators manual how you do-it and pag.17 to 19 . please check for When “SB*” is selected in SPEAKERS setting mode,
the SURROUND BACK distance cannot be set.
so if you dont have check this site, who has the manual to help you how to config.
http://safemanuals.com/user-guide-instructions-owner-manual/PIONEER/VSX-D710S-_E is from 710s, but have 810s also
Jan 08, 2010 | Pioneer VSX-D810S Receiver
How to connect 901 equalizer to a Pioneer VSX 47TX
I have a VSX-36TX so this is how it's going to work...
You will need a separate stereo amplifier for the 901's to accomodate the need for the Active EQ. There is no way to separate your receiver's front L&R channel preamplifiers from their amplifiers.
I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds. You would probably just get a nice 2-channel amplier for the 901's. However, the VSX 47TX doesn't provide power for a Subwoofer, should you decide to get one, so you would need another amplifier channel for that, too. Therefore, you might look around for a powerful 3- or 4-channel amplifier so you could drive the Sub, too.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 100W for mine and it has plenty of steam for the 901's.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Not what you might want to hear but 901's have special requirements. I've had mine for 25 years and have no regrets.
A separate subwoofer channel on the amp could be used. Just run a single RCA channel from Sub OUT to one available channel IN on the amp and attach the subwoofer to it. Two would work, also. That's what I do. You could use a 1-2 RCA splitter to feed two avaailable channels on a 4-channel amp. The iterations are many. Have fun.
Jan 24, 2009 | Bose 901 VI Main / Stereo Speaker
Stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Oct 07, 2007 | Pioneer VSX-816-K/S Receiver
How do i connect non passive woofer
This receiver can only take a self powered subwoofer I'm afraid. You could get a power amp and power the sub like that but in the long run I really think you would be happyer to get a new subwoofer. Good Luck
Jun 07, 2007 | Pioneer VSX-516-K/S Amplifier
Connections
Follow these; 1-Get an Xbox 360 HD cable (see the picture1 below) 2-Connect the red and white plugs to one of your amplifier's empty inputs. 3-Connect the VGA plug to the LCD directly By following these instructions you'll be able to get surround sound from your amplifier as long as you keep it turned on. 2nd solution could be that; (if you have some other equipments connected to the amplifier such as dvd, cd, etc.) 1-Get the above-mentioned HD Cable and get a VGA to S-Video adapter (a small piece of equipment) 2-Do the same thing as mentioned in the 2nd above 3-This time, you're gonna select a VIDEO INPUT (video1, video2,etc.) on your amplifier's input selector. Affix the VGA plug of your HD cable to the S-Video adapter, and connect it to an empty S-Video input slot at the back side of the amp. 4-Get a simple RCA cable or a digital coax cable (up to you) to make a connection between the "monitor out" slot of the amp. and the "video in" slot of the LCD. It's important that which video input you've selected in your amp. to make this connection. For instance, if you choose "VIDEO 1", you will have to connect all plugs (Audio and Video) via VIDEO 1 slots. Good luck
Apr 17, 2007 | Pioneer VSX-D510 Receiver
Pioneer VSX-818V-K Receiver Logo
307 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
