Question about Canon PIXMA MP510 All-In-One InkJet Printer
Cyan Ink cartridge Not printing correctly
Recenlty put in new Cyan ink into my MP510 printer.
All clours work fine except Cyan which prints but with smudged lines through it. I've run a deep clean 6 times and normal clean about 8.
cleaned the printer heads. Now out of Ideas. Anything elses I can try? or do I throw the **** printer out and buy a decent one?
  • talion78 Apr 18, 2009
    Is it the Chip on the cartridge causing the problem or the cartridge itself?
    I don't want to throw away good ink if it's just the chip. I can replace it with the chip from a new cartridge once ink run out?
    cheers
  • 385 Answers
After all these tests, then it's defective.
Swap out the cartridge before it damages the printer permanently,
Regards
Ric.
Posted on Apr 17, 2009
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
I am unable to print in grayscale only because my Cyan ink has run out. why is that affecting my ability to print in black ink?
The technology of the printer is combinations of all parts and accessory like cartridges and other assembly we can’t ignore 1 of them, you need to install the color cartridge to work around.
Nov 24, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Cannon MP510 printer has Error, - The type of print head
I solved this on mine by removing and reinstalling the print head.
1. Remove and set aside the ink cartidges (don't make a mess)
2. lift the gray print head lock lever that is to the left of where the ink cartridges go.
3. Lift out the print head out without touching the ink ports inside, the contacts on the back, or the print nozzles on the bottom. The print head is the grey thing with circular ink ports that seat the ink cartridges. there are good pictures in the PDF of the Easy Setup Instructions available on the Canon Printer website. Look under the printer, then support, then downloads: http://gdlp01.c-wss.com/gds/0900002776/mp510_esi_us_v2.pdf .
4. Put the print head back in, lock the lever, reinstall the cartridges in the roper positions. And voila!
If this doesn't work you may actually need a new print head.
Oct 08, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Pixma ip4200 willl not print Cyan
I think the problm lies between the ink tank and the printhead. When this passage runs dry, sometimes it takes time for the ink to fill this passage again. Try printing again after a day or two.
Jul 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Pixma IP4200- not printing color
If it's a generic ink, try another one, if it's a Canon ink, make sure the tape on top is removed, it covers an air vent, if that doesn't help, you need a new printhead, QY6-0059-000 around $40.00
Jul 02, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer won't print correctly
ensure the ink cartiges r original and check head cleaning process
Feb 14, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Ink cartridge full, but printing as if out/low
I have found using 3 r d party inks in Canon printers will mess them up fast but the ones with the contacts don't work period
Dec 01, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Cyan ink tank not printing
clogging in cyan nozzles in printhead. try to clean or deep clean printhead from printer software.
Sep 17, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
May 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
236 people viewed this question
old marine
old marine
