Question about Maytag MES5775BAF / MES5775BAN / MES5775BAB Electric Kitchen Range
Single element in 3-way burner won't work
I have had a Maytag Model MES5775BAB 30" slide-in range for exactly 3 years. The single element in the 3-way burner will not get hot. This burner has two controls - one to select the burner size (single, dual or triple) and the other knob controls the heat.
I guess I need to know about how much this is going to cost to repair. It just really frosts my cake that this element failed after three years.
Thanks for your help.
  • Maytag Master
  • 3,497 Answers
Hey Janice,
Sorry to hear this.. but, here is a site that will answer your question more completely.. ( I think this is a complete replacement job).. and if your are mechanically inclined, you might be able to do it yourself... good luck,,
as far as costs... that's such a wide range of "prices per hour or by the job", it would not be feasible to put a $$$ figure on here..
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/94552-glass-surface-triple-element-replacement.html
Posted on Jun 19, 2017
5 Suggested Answers
  • 146 Answers
SOURCE: Large Dual Element Is Not Working
Check the center ring. If it is open replace it.
Posted on Dec 21, 2007
tzweeb
  • 318 Answers
SOURCE: Hot Surface Light Stays On
you do have a top burner sensor that has failed. the hard thing is to figure out which one. most of these units have a 5 year part warranty, but you have to pay for an authorized servicer replace it for you.
if you want to figure it out yourself, you will have to find which of the wires, from the burner sensor, controls the indicator light. its not hard as it is usually the smaller one. each burner has a sensor and if you are certain you can work with the electricity on, its just a process of elimination.
unplug the unit from the wall, then take off the wire from 1 burner at a time, tape it off, to prevent shorting to ground, then plug back in and see if the light has gone out.
then you can order the new sensor, but on some models, you have to get the whole burner and sensor assembly.
Posted on Dec 28, 2008
ftw1952
  • 10319 Answers
SOURCE: Model MES5770AAB Serial 11517659WK The single
Ten to one the elements will have to be changed also. Call or email Maytag about your dilema. You can simply reject to pay me also on this one
Posted on Jan 24, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Maytag Gas Range With Touch Control Model: CRG9800C,
Sorry to read about your problem, I hope this helps you out.
You could have 3 different problems.
1. defective gas control valve to the oven
2. defective temp probe
3. defective gas control knob
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
Model MES5770AAB Serial 11517659WK The single element, 700 watts came with a wiring kit for a new connections. My range has "Old connection type 1" . the moddification kit (A-30001, Revision 4) shows...
Jan 21, 2010 | Maytag Kitchen Ranges
Oven lights, but temp does not get above 100
The gas burner is broken. There is an upper burner and a lower burner. In-order for both burners to turn on, both must be working to let the gas turn on. If one burner element is out the oven wont get hot just warm.
Apr 29, 2009 | Maytag 30" Self-Cleaning Slide-In Gas...
Maytag oven top heating element won't come on unless on broil
You are probably going to find the lower heating element has failed. Your symptoms describe that failure exactly.
Reply back if you want instruction as to how to repair.
Feb 15, 2009 | Whirlpool RBS275PD Electric Single Oven
Range is shuting off
wen it became hot the water content from air turned it off.
Jan 02, 2009 | Maytag 30" Built-In Single Electric Wall...
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Viking Range
I'm having a similar problem. I don't know the exact fix yet, I'm just starting to research. Check this link: http://www.applianceguru.com/forum1/1916.html
It sounds like the ignitors are suspect. This may be a weak component for Vikings. This link recommends a Maytag replacement part.
Dec 08, 2007 | Viking VGSC366-6B Gas Kitchen Range
Maytag MES5775BAF / MES5775BAN / MES5775BAB Electric Kitchen Range Logo
50 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
