Question about Liquid Video E15LCD1 15"
No audio from lcd monitor (viewsonic) after disconnecting my speakers. (New monitor has built-in speakers)
I just connected a new viewsonic hd lcd 22" monitor with built-in speakers. I disconnected my old speakers, and now I have no sound. There are minimal setup instructions on the new monitor in many languages of very little help.
  • 1 more comment
  • honey0786 Jan 28, 2009
    HI all,
    i have a LCD monitor from pro view which has inbuilt speaker on it, when i use a cable there is no sound on speaker but when i use a head phone from sound jack i am able to hear, which mean there is some problem with my LCD monitor speakers, could you please help
  • Anonymous Mar 25, 2009
    have a monitor that has no audio
  • Anonymous Apr 16, 2009
    "No audio from lcd monitor (viewsonic) after disconnecting my speakers. (New monitor has built-in speakers
Make sure you hook up the third gree socket on back of monitor to PC that was my problem and solution to my model monitor LCD
Posted on May 28, 2008
Iv no sound coming from my monitor speakers but if the child plus a earphone into the back of my pc he can hear sound can u help me plz nadine1 :)
Posted on Jan 02, 2009
I have my syncmaster 2220wm hooked up to my laptop. How can I get the monitor sound? It is only using the speakers on my laptop...??
Hello a 2250wm is actually a Viewsonic monitor not a Samsung monitor. To get the built in speakers to work you will need to connect the audio cable from your laptop to the monitor audio jack. This cable should have come with your monitor, it will have a headphone 3.5mm plug on both ends of the cable. If you do not have this cable yo will need to get one before you can make the speakers work right. Here is a link so you can get the cable if you need one.
http://www.ccl-la.com/catalog/product_info.php?cPath=83_86&products_id=176
Dec 05, 2012 | Samsung SyncMaster 2220WM 22" LCD Monitor
What should the connection from my vx2250 viewsonic monitor to my desktop look like?
If your monitor has built-in speakers, you should have a connecting cable with stereo mini plugs on both ends installed between the line out connector (usually green) of your sound card and the audio input connector on the monitor. I have an HP monitor with built-in speakers and that's how it is connected
Nov 08, 2012 | Viewsonic Corporation Viewsonic...
Audio will not work with the built in speakers
Make sure the plug is in the green connector. Then check the sound setting in windows to make sure it is sending the sound through the proper connecton.
Sep 21, 2011 | ViewSonic VG2228WM 22 inch LCD Monitor
Hi, I have ViewSonic VX2235wm-5 22"
It appear the monitor has been connected to another system unit than the default. disconnect the entire systems and reconnect altogether, restart the computer to allow the unit to recognise the new monitor. should diplay possible soluiton, else follow the instrcutions below
1.locate the control panel where the options of systems setting is displyed.
2. a click should dispaly a list among which is device speaker options
3. the computer speaker could be updated by clicking to install drivers or codes acquirable from the network.
alternately
1. click on the hardware icons located after locating and clicking into control panel.
2. on the list of add delete hardware provides the option to attempt to delete the speaker codes
3. a delete of the speaker drivers on system restart would prompt the user to update the speakers. A click on the prompt should acquire the necessary installation kit patches from an internet connection if any.
Dec 06, 2010 | ViewSonic VX2235WM Monitor
Hi , I own a viewsonic LCD monitor model va1912w. My system has Windows XP. There is no sound from the monitor even after connecting the sound cable from CPU to monitor's audio jack. I have already...
http://www.viewsonic.com/support/downloads/drivers/?prod_name=1912
Try the above link for Vista or XP drivers which may be used with Windows 7 in some cases.
The va1912wb came up when I searched under 1912.
This driver is available directly from the viewsonic.com site.
Uninstall the other driver if possible.
Aug 08, 2010 | ViewSonic VA1912w 19" LCD Monitor
I have a syncmater 2333 HD and after connecting to my pc, i seemed to have lost all sound. when connecting speakers and earphones, there is still no sound. thanks
Did you plug in the audio cable to the back of the computer? If so, this may have disabled the front audio connections (or vise-versa). Try unplugging the audio cable from the computer (that is connected to the monitor) and see if your headphones work. If so, there is the solution to that problem.
Check the audio connection on the back of the monitor and double check that it is plugged into the correct port on the back of the computer. If the monitor has amplified speakers, it would be a good idea to connect to the 'line-out' connector on your computer. This would avoid disabling your front audio panel.
Lastly, check the volume on your monitor's built in speakers. This monitor can double as an LCD television, so it most likely has a separate volume control (that defaults to 0).
Oct 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Bought a new viewsonic moniter,where do plug the speakers into
I brought pc with ViewSonic VA1912wb 19" LCD it have in built speakers or not how i connect get suond with out externals speakers
Jun 28, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Built in speakers not regestering on computer
Do you have a Sound Card installed in your computer, if not. Buy one at any local pars store. Now, if you have one installed. Then you must update your drivers or you are plugging your cable to a wrong output. Use the light green 1/8" connection.
Mar 11, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
No sound
you need to reinstall your soundcard on the computer
Dec 06, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Installed new monitor, lost my sound
If your previous monitor had built in speakers and your new monitor does not you are going to have to purchase new speakers. If your new lcd monitor has an audio input you can purcahse a sterio mini jack cable for under $10 at any store that sells computer stuff (circuit city, best buy, walmart, target, etc). Simply plug one end into your monitor and the other end into your computers audio output jack (usually color coded green). Now of course if that monitor does not have built in speakers your only option is to purcahse a set of speakers for the computer. These usually start at around $15.
Aug 10, 2007 | LG Flatron MW-30LZ10 30" LCD Monitor
Liquid Video E15LCD1 15" Logo
1,995 people viewed this question
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Mark Gough
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
