Question about HP Color LaserJet 3500 Printer
Plastic cover inhside door is ripped.
I have a HP 3550 color printer. I was installing a new toner cartridge in it today and when I closed the fromt cover, the printer started into its cycle. However, this time it started making a h9orable noise. I opened the front again and saw that the plastic sheet that covers the internal parts was ripped. It is the plastic sheet that goes against the toner cartridges. I would like to know what this part is called, the item number and where I can purchase the part at within a reawsonable price. My email address is tomruss@yahoo.com. Thank you for your assistance.
Found a company that had enough detail on their site to give me the name and the product number. The product number is G3658A. Thanks.
Posted on Apr 18, 2009
Xerox 3550 toner install
Replace the print cartridge using the following instructions:
1. Release both latches on the side of the front door and open the door.
2. Pull the print cartridge out.
3. Remove the new print cartridge from its bag.
4. Slowly shake the cartridge five or six times to distribute the toner evenly inside the cartridge. It will provide maximum copies per cartridge.
Note: If toner gets on your clothing, wipe it off with a dry cloth and wash clothing in cold water. Hot water sets toner into fabric.
CAUTION: Do not touch the green underside of the print cartridge. Use the handle on the cartridge to avoid touching this area.
5. Hold the print cartridge by the handle and slowly insert the cartridge into the opening in the machine.
6. Tabs on the sides of the cartridge and corresponding grooves within the machine will guide the cartridge into the correct position until it locks into place completely.
7. Close the front door. Make sure that the cover is securely closed.
Nov 22, 2012 | Xerox 3550 AllInOne Laser Printer
How do you place cartrige in printer
Step eight: Install the cartridges
  1. Raise the top cover of the product. Figure 5: Raise the cover c00830210.jpg
  2. Remove the new cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 6: Remove the tapec00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  3. Slide the new cartridge forward into the empty slot. Then gently push the upper part of the cartridge forward until it clicks into place.
    • Slide the tri-color cartridge into the left slot.
    • Slide the black or photo cartridge into the right slot.
    Figure 7: Insert the cartridgec00830211.jpg
  4. Close the cartridge door. Figure 8: Close the cartridge doorc00830212.jpg
Aug 08, 2010 | HP Officejet 5780 Printer
Hp 3550 not reading toner
Initially check the silver metal parts on sides of toner are not covered with any plastic tapes, then also check that the spring for earthing on the right side of toner is fitted properly.
Also clean the inner parts of printer which comes in contact with cartridge sensing assembly and then reinsert the toner.also unplug and replug-in the printer power cord once if necessary to reset the printer.
thanks.
Aug 31, 2009 | Sharp AR-168S Copier
Hp color laserjet 3550 - error message "cartridges not engaged"
here are the codes for the error you are getting
10.92.00 Black toner
10.92.01 Cyan
10.92.02 Magenta
10.92.03 Yellow
The fix is either the toner lock is broken. Contacts on the left side of printer are damaged.
There is a complete proceedure for replacing the the toner locks which comes in a kit you can order from precisionroller.com. this takes about an hour.
If the contacts are damaged you will have to replace the whole plastic part on the left side behind all of the electronics. It takes about an hour
Jun 14, 2009 | HP Color LaserJet 3500 Printer
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
This is how to Install or replace the Toner Cartridge.
Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
Cheers!!
Apr 21, 2009 | Dell 3010cn Laser Printer
Yellow Toner leak inside printer
I generally use small soft-bristle brushes to move the toner to locations where I can easily get to it with a small hand-held vacuum unit and just **** it right out.
Apr 07, 2009 | HP Color Laserjet 3550 Printer
LaserJet 3550: override chip on toner cartridge to continue print
Disable Carts is for service tech troubleshooting.
You will have to replace. All prints use all cartriges every time.
Jan 20, 2009 | HP Color LaserJet 2600n Printer
If you drop down the door to the toners & remove the toners that the machine says are not engaged. Now look on the right side where the toners are suppose to slide in, more then likely with this model you will find a small black plastic piece that is loose in the slot. you may need a needle nose pliers to remove it. (these pieces are remnants of an old cartridge) once removed, pop the toners back in and whala!! Hope this helps you out and if it does, please mark as a fixya...thanks Dan
Sep 24, 2008 | HP Color Laserjet 3550 Printer
How to remove drum unit from kyocera fs 1920
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Aug 04, 2008 | Office Equipment & Supplies
HP Color LaserJet 3500 Printer Logo
102 people viewed this question
Seeker5211
Seeker5211
