Question about Samsung HLP4663W 46" Rear Projection HDTV
There is no picture and it shuts down and then tries to restart
2 lamps flashing and no picture.
  • 371 Answers
Your set is not receiving a valid signal for the resolution of the set and shuts down as a self-protective measure
so you have to make sure the source is sending what the set needs and then it will show a picture at the
acceptable resolution.
Do you know the range of resolutions allowed with your set?
They are:
Broadcast Format Displayed: 720p (HDTV) · 480p (EDTV) · 480i (SDTV) Broadcast Format Supported: 720p (HDTV) Digital TV Standard: HDTV - HDTV receiver is integrated. Built-in Tuner: NTSC Aspect Ratio: 16:9 · 14:9
Posted on Apr 17, 2009
Lamp keeps cycling on and off.
the circuit is closed somewhere it shouldnt be
Apr 13, 2013 | Sharp XR-10X Multimedia Projector
The picture has suddenly gone dark. We can still see the picture, however it is really dark. We tried shutting it completely down and unplugging and restarting it. We tried to adjust the color via the...
The tv LED light on the tv front bazel frame face have the word "LAMP" light up or blinking?Yes.The tv projection lamp been inside this tv like 1 1/2 or 2 years already,tv used it everydays like 4 or 5 hrs daily?Yes.Than the tv projection lamp life are over,that why it dim picture tv now must have it tv projection lamp to be replaced.
Jun 12, 2011 | Samsung SP50L6HX 50" DLP HDTV
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
AKAI PT50DL14X\SMS - LAMP INDICATOR (GREEN)
AKAI PT50DL14XSMS - LAMP INDICATOR (GREEN) FLASHES ABOUT 20 TIMES - CAN HEAR FAN RUNNING AND LOOKING THRU LAMP GRILLES CAN SEE BRIGHT BULB LITE - NO PICTURE COMES ON - AFTER ABOUT 30 SECONDS EVRYTHING SHUTS DOWN
Nov 02, 2009 | Akai PT50DL24 Television
When I power the TV on there is no picture, the lamp light is flashing, and there is a squeaking noise coming from there rear of the TV. It kind of sounds like a wheel turning and rubbing against...
The squeeking sound could be the high voltage trying to strike the lamp, it will try several times to strike the lamp then shutd down. Take the bulb out and see if it s blown. Even if it is not blowen it sounds like you have a bad bulb.
Sep 01, 2009 | Samsung HL-R4667W Rear Projection...
My brightness is very low. I can't see anything
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 14, 2009 | Toshiba Computers & Internet
62HM95 noises
Sometimes the ballast can whine but most times it is the color wheel as it has a motor that spins it at high RPM.As they fail they'll make a squealing type noise and keep the set from coming up. If the you can pinpoint the sound (it would be right nest to the lamp) then its the wheel.
Apr 27, 2009 | Televison & Video
Samsung HLP4663W 46" Rear Projection HDTV Logo
254 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
