Question about Canon PowerShot A590 IS Digital Camera
Our pc's do not recieve a signal from the camera. It worked now it doesn't. I try to connect camera to PC but no signal
Cannot download picture to PC. It was working fine. Now tried to connect and getting a message - camera not connected. I check the plug - went to another PC with software and still Message can not locate camera. I turned off and on moved the slide up and down still not connection. I used another cord
  • Canon Master
  • 4,738 Answers
It's very hard to troubleshoot software problems online, and it likely is a software issue. But why put up with the headaches of bad software in the first place? Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Posted on Apr 18, 2009
Computer doesn't recongnize sony camera usb
To download the pictures you need the driver for the camera ...this can be downloaded from the support site if you do not have it ..but from what you said it seam that the issue may be of other cause..
The camera need to be powered and on ..in the moment you connect it to the computer ..and also you need to confirm the pc connection from the camera in the moment you connect ti .make sure you have its driver installed .
Try to connect in a different usb port ..cause even if the driver is missing the computer should react on the usb device being plugged and ask for the driver.
If no port will react ..try the camera oin another computer ..and like I said always make sure it is powered and on ... If it makes no reaction in another computer ..than something is wrong with the camera .Another method to download the pictures..is to use the card from the camera directly into a card reader and copy the pictures from it ..
here is a link for the driver if you need it ..
http://esupport.sony.com/US/perl/model-home.pl?mdl=DSCW370G&template_id=1&region_id=1&tab=download#/downloadTab
this is teh picture browser it uses...be sure you select the operation system you run ..and also make sure you download the full program first and the upgrade after ..cause the update download may not work without the original one ..(down on the list ) ..
Good luck !
Nov 25, 2011 | HP Pavilion dv9000z Notebook
My camera (canon powershot a580) doesn't make a connection to the pc anymore, so I cannot put my pictures on the pc.
Good day!!!!
if you can't connect to the PC using USB try test other USB
if you test other USB and still can't connect..you need to give it to the qualified technician..
but for the mean time you can use the sd card of your camera then insert it to the card reader..
after that you can copy the picture from camera to the PC.
Thank for using fixya...
Aug 26, 2011 | Cameras
I recieved a Bresser Biolux al as a gift, but unfortunatly the usb camera that comes with it doesn't seem to work, there is no picture on my pc when i chose 'open the camera'. I have downloaded...
If your pictures in camera memory, try to move it to your memory card. While your camera does not paired successfully with PC, you use the card reader to your pictures by PC.
Aug 05, 2011 | Cameras
I install the software but I am unable to download photos and videos...I follow instructions but I can't and I don't know why. I connect the camera after I've installed the software and...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 21, 2011 | Fuji Finepix Z20fd Digital Camera
Cannot download pictures. red light flashes when connecting to computer and computer doesn't register the device
For this issue you just need to reinstall the software or driver for your camera. Then restart your Pc. Then you need to connect your camera again to check if the pc will recognized it. You may also try to check if the cable you're using to connect your camera to your pc is not damaged because usually the cable is the one causing the issue.
Hope this help you a bit. Have a great day.
May 18, 2011 | Canon PowerShot S3 IS Digital Camera
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
Sigmatel s4 software
i have a sigatel s4 model china mobile, i want the software to download from my pc pls help out
Oct 01, 2008 | Handmark Software MobileLists (950142) for...
Downloading videos
are you using the software that came with the camera
it sounds like you are trying to just move the video from the camera to your pc using the microsoft operating system software. microsoft operating software doesn't recognize the file type the camera saved the video in.
Dec 16, 2007 | Fuji FinePix A345 Digital Camera
Canon rebel xt
If you are using the camera software then remove it and Windows do the Work. If are sill having trouble, Then invest in a USB card reader.
Apr 23, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon PowerShot A590 IS Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
