Question about HP Color LaserJet 3500 Printer
HP 3500 color printer
My printer is not closing proper.....
  • 23 Answers
If you can see what is stopping the door from closing, and it appears to be on the right side of the printer near the top where the cartridge engaging pins are, and you remove all the cartridges and transfer belt and the door closes well, you may want to try this: There is a small silver screw at the top of the right corner of the case. When our front door would not close properly with the cartridges and transfer belt assembly installed, I took off the right side cover and took out that top corner screw. Then I slid the long white engaging rack that is on the lower right side of the printer toward the front door, which retracted those cartridge pins that are triangularly-shaped on their ends. Once the door would close properly with the cartridges and the transfer belt installed,and the pins engaged properly to open the cartridges as the door closed, I put the top corner screw back in and the side cover back on. I hope that helps you.
Posted on Oct 02, 2007
SOURCE:
HP Color LaserJet 3500 Printer Problem 59.99 printer rorror
The Pickup/Feed assembly needs replacing (part number RM1-0765-070CN for HP 3500/3550 for ordering a new one).
Dec 21, 2010 | HP Color LaserJet 3500 Printer
Catridge memory error on magenta
Kindly Open and close the front door.
Check wether your cartridge is properly mounted.
Feb 17, 2010 | HP Color LaserJet 3500 Printer
How do I check current ink levels in cartridges in my HP Laser Jet 3500
I have an hp 3500 printer myself...simpley print out a supplies status page.
on the control panel go to information than scroll thru that until you see supply status page.. i'm not near my machine now.. but take a little time going thru the menus you'll see supplies status page..
i'm using my hp 3500 as a parts machine..so I don't need it.
would you like to purchase the old fuser/transfer belt toner cartridge for realy cheap...i live in PA if you are close..
Jan 06, 2010 | HP Color LaserJet 3500 Printer
50.1 fuser error not fixed by instruction on machine; HP color laserject 3500
17 posts - 8 authors - Last post: 23 MarWe are getting a 50.1 fuser error with our Colour Laserjet 3500 printer ... fuser from HP in the UK, but was told that they are not currently available ... hi I have the same problem error 50.1 with two machine 3500/3550 ...
www.fixyourownprinter.com/forums/laser/31146
Dec 04, 2009 | HP Color LaserJet 3500 Printer
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
I have hp color laserjet 3500 is printing only cerrent page
Try reinstalling the printer driver software again. This could solve your problem.
Jan 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Front door wont close properly
check the swing arms to see if they go up and down properly. They are behind the print cartridges and are attached to the plastic piece which stops the cartridges from falling inside the printer. make sure those are all guided and aligned correctly. Thirdly, if you are looking at the printer from the front, take off the side panel on your RIGHT (3 screws total--if im not mistaken) and look at the arm movement when you open and close the door. check the left side for the same movement. I've worked with a few hp 3500's and 36's, but im not a pro! just some suggestions.
Dec 15, 2008 | HP Color LaserJet 3500 Printer
HP COLOR LASERJET 3500
Hi!
If you could possibly manage to access the machine status menu and have it print to check the drum's life, fuser life, developer, etc.. pls refer. Kindly replace the toner cartridge accordingly use the menu settings when replacing any color if needed. Please print solid image or block in each color Cyan, Magenta, Yellow and Balck. Well see if what color causing the problem. Please let me know the print result it may be; washed out or too light, too bright or black, double image, or not clean. Don't hesistate to contact me again about the result.
Best regards,
Rosener Guyano
Jan 31, 2008 | HP Color LaserJet 3500 Printer
HP Color LaserJet 3500 Printer Logo
875 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
