Question about HP Office Equipment & Supplies
Printer seems to have a broken part inside - it will not grab paper to pull through
  • 385 Answers
If over a few months old,with regular use.
Try cleaning the feed rollers,
Rotate them as you clean them.
Distilled water, Lint free cloth.
Regards
Richard.
Posted on Apr 19, 2009
I have a paper jam inside my mx726 and i have apple safari which seems to be blocking the paper jam videos. Can you tell me how to open printer please?
Try removing the paper tray(s) and see if you can see the jam through the bottom. If not, open the top, grab end of the paper and pull it out. Then power the printer off/on.
Feb 27, 2015 | Canon PIXMA Office Equipment & Supplies
Epson 300 will not grab paper. Seems to sound
Give it a good check to be sure the belt drive or other rotating parts are not broken or clogged by dirt.
Oct 25, 2009 | Epson Stylus Photo R320 InkJet Printer
How to remove jammed paper in the Samsung ML-2240 laser printer
If there are papers stick out of the top in the recieving tray gently wriggle them back and forth until they are free. Then, open up printer and the remove the ink cartidge. The papers lying mostly on the inside need to be pulled from the inside. The papers that have just been picked up and are mostly still lying in the paper feeder can be pulled out from there as well (although you may want to remove all the paper that hasn't been grabbed yet). Just keep wriggling back and forth gently so as not to tear the paper and lose a little scrap inside.
Oct 06, 2009 | Samsung ML-2240 Laser Printer
Paper feed problem
this is the rare case: there could be two problem 1) either some bit of paper would have been stucked inside the printer 2) or else the roller is not smooth. the roller inside the printer helps to draw out the paper gently.
Jun 15, 2009 | HP DeskJet 6122 InkJet Printer
Cartridges crash against the inside of the printer
100 percent that said small piece of plastic had give you a trouble in to your said priter. open your printer and find or locate that small plastic where come from inside your printer find the broken plastis inside your printer and join it
May 04, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Grabbing the paper pulling it in at the left hand side
1) Try to adjust lateral directing limiters for paper.
2) See attentively inside device no there stranger subject such as pencil or piece of the torn paper. Use the lighting of the lamp or flash-light.
Mar 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
PAPER JAM
Rotate tires. Pull out paper tray. Pull down on red low paper indicator at left bottom. Two rollers come down on axel near center. I pulled off the rubber tire like roller, then twisted the roller inside out and reinstalled it with the fresh side out.
If tires dry out again will probably buy new ones from ebay.
Jun 26, 2008 | Lexmark E232 Laser Printer
Hp officejet 7310
please check gear train and confirm no broken one-check of selonid not working in a right way and no foreign object droped inside(like pins).-check of smoth actuation of paper present detector.(in place and movement when you put papers
Mar 01, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Paper Feed Error
Your saying the printer grabs the paper on the one side more than the other?
Nov 13, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
29 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
