Question about Sharp Televison & Video
Sharp LC 46sb54u won't turn on. I have no error codes or lights. I am using a known good outlet and the TV just won't power up. Please help
  • 6,784 Answers
Hi, this sharp flat panel is experiencing a loss of proper current flow due to the failure of the main power circuit board. This board will need to be replaced before it can become operational once more. You will have to replace the AC inlet unit as well. the PB and AC inlet unit work together. i will list the parts and there respective part numbers below.
POWER SUPPLY (DPS-304BP-1 A) # RDENCA235WJQZ $323.95
AC INLET UNIT # RUNTKA317WJQZ $36.95
Posted on Apr 17, 2009
Can I use the USB service port to power a Bluetooth transmitter
Hi Frank,
If you are referring to using your TV as the USB port... you cannot. It's strictly for service. I have tried as well and it won't recognize it. It's strictly for servicing.
Mar 01, 2016 | Sharp LC-46SB54U LCD TV 46 inch Class,...
The tv goes off but there is audio.
If you have sound the inverter board has failed,or one of the ccl lamps has died .when you switch on the powersupply sends power but on receiving a fault condition from either of the two faults above will shut down power to the inverter board.
Len..
Apr 11, 2014 | Sharp LC-46SB54U LCD TV 46 inch Class,...
Power and OPC blinks, TV will not change Input modes
Try removing set and or a box if used from power for several minutes.
Dec 23, 2012 | Sharp LC-46SB54U LCD TV 46 inch Class,...
Sharp lc-46sb54u wont come on nor the wii or direct box
Sounds like wall out or no voltage to the equipment; does a lamp or other appliance work when plugged into same outlet?
Did you have some kind of power outage?
It seems unlikely all three would be dead at same time as your question states-----circuit breaker tripped?
Mar 19, 2012 | Sharp LC46SB54U 46 in. LCD TV
Sharp LC -46SB54U will not turn on. The green power light flashes twice, then the green power light and green OPC light flash once together. This pattern then repeats itself over an over again. The tv is...
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Do take care.....
Jun 16, 2011 | Sharp LC46SB54U 46 in. LCD TV
I have a 46 inch Sharp model #LC-46SB54U. The
no_picture.jpg Part Number NOTE Description Product Note Substitute Part n/a Total Availability 0 Estimated Ship Date no longer available
Apr 27, 2010 | Sharp Televison & Video
Need owners manual for Sharp 46'lCD TV Mod.#LC-46SB54U
Owners manuel can be found at www.managemyhome.com right hand side--enter man and model #, to avoid having to sign up, right click and open in a new window when the pdf file pulls up. Its their I just checked.
Feb 24, 2010 | Sharp LC46SB54U 46 in. LCD TV
Error code e203 tv sharp lc-46sb54u
My sharp manual says E203 means "No broadcast now".
Under possible solution, it says " Check the broadcast time in the program guide".
My manual says nothing else after that.
I hope that helps. Please rate me. :)
Feb 28, 2009 | Sharp LC46SB54U 46 in. LCD TV
Televison & Video Logo
73 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
