Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite Front-Loading Washer Model 4596 Locked control pane
Washer was started without water valve open. FH code. Pushed cancel button twice and disconnected from power. Unable to reset cycle, unable to open washer door. How do I reset the washer control and open washer door.
  • dgeyer324 Apr 18, 2009
    Proposed standard solutions were not successful. However, I unlocked the door as you suggested and restarted the washer with the door open. F11 code, I closed the door and pushed the start button and the washer restarted and ran fine. Thanks
  • 15,935 Answers
FH Condition:
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Check/Repair:
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
  • 1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
I myself have rarely run into this issue, and when I did, it was mainly caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens. To Manually unlock the door lock system: 1. Unplug the power cord from the outlet. 2. Remove the lower toe panel. 3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly. 4. Located on the bottom of the door latch assembly is a tear-drop shaped tab. 5. Gently pull the tab down about 1/4 inch or until a click is heard. 6. The door may now be opened Something else has failed other than just the no water FH condition. A service call is in order - as there is no end-user reset or quick fix for this. The following Tech Tip may be useful tou you as well. "F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It’s a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa!!
Posted on Apr 17, 2009
  • blueextc3221
    blueextc3221 Apr 18, 2009
    thats part of troubleshooting.
    taking one item at a time in logical sequence.
    Glad you could get the door open with my suggestion.
    I think the logic was out of order - and the only way to move on is to clear the doorlock sensor by opening it manually.
    Thanks again for using FixYa!!
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    Error code hf
    Hello & Welcome to FixYa
    FH error is displayed when control board detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
    Kevin
    Aug 08, 2011 | Kenmore Elite 45986 Front Load Washer
    FH error appears about a minute or two after I select the "on" button
    FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
    Kevin
    Jul 19, 2011 | Kenmore Elite 45986 Front Load Washer
    Error code rads H&F
    Kevin
    Jun 10, 2011 | Kenmore Elite 45986 Front Load Washer
    The washer was giving F and H warnings I may have had too many clothes for one load. Thank you Kenmore Elite front load washer
    Kevin
    Jun 01, 2011 | Kenmore Elite 45986 Front Load Washer
    I ordered and bought the control panel part for my kenmore elite front load washer but the washer is still not washing it's flashin FH
    fh is a water problem,does it fill with water?....... FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
    Or
    Potential Causes
    - Make sure that both valves at the water source(s) are turned on all the way.
    - Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    - Verify inlet valve operation
    - Verify Drain pump operation
    - Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
    • Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
    Replace failed component.
    Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz1HSpZo0dW
    Mar 23, 2011 | Kenmore Elite 45986 Front Load Washer
    FH appears
  • 2
  • 3
  • 4
  • 5
  • If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
  • Dec 14, 2010 | Whirlpool Washing Machines
    Kenmore Elite HE3 Error FH I forgot to turn the water hoses on when I started a load. The FH error sounded at 33 minutes of a 45 minute cycle. I can't reset the machine now. It is stuck. It is unplugged....
    according to kenmore, you should press the "pause/cancel" button twice and it should release it.  it may also have locked up the CCU, central control module and might need to be replaced.
    Aug 02, 2010 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite He3t front load washer - error code reads H & F
    the F code is a puwer outige. This is how to fix
    Select PAUSE/CANCEL twice to cancel the cycle. Select
    DRAIN & SPIN if there is excessive water in the washer.
    Re-select cycle and press START. If the problem remains, call
    for service.
    This is what an HF code is.
    "FH" (Water Inlet Problem--no water or insufficient water
    supply)
    Select PAUSE/CANCEL twice to cancel the cycle. Unplug
    washer or disconnect power.
    Are water faucets completely turned on?
    Are screens at inlet hose connection to washer clogged?
    Are water inlet hoses kinked?
    Are water inlet hoses frozen?
    Plug in washer or reconnect power. Re-select cycle and press
    START. If the problem remains, call for service.
    Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    80 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Carew
