Question about Videoseven R17PS 17" LCD Monitor
Screen flashing differnet colours
Hiya, I have this monitor and it flashes White, Black,Red,Green,Blue,Yellow,Magenta,Cyan comtiuously with only power connected. It appears my daughter has been playing with the buttons looks like it's in some sort of service/test mode. I've tried unplugging and holding various buttons down but to no avail. Any help would be appreciated.
  • Anonymous Apr 01, 2008
    THERES DIFFERENT COLORS FLASHING
My Benq lcd monitor does the same thing.
Posted on Dec 10, 2007
  • Artysue May 12, 2008
    All fixed. Technician rang company who had never heard of it but eventually told technician to press a few buttons on front of monitor and hey presto, gone!
If black ink is out, will copy in color possible from pc? Also how do I reset this printer?
Dear
Since the model is not found, its difficult to say. however in most cases the subtractive colors are used ie cyan,magenta and yellow. with mixing these white is produced but in case of basic color used ie. red,green and yellow, on mixing these black color is produced. Mostly cyan, magenta and yellow is used hence you can not produce black color so the a complete color print not possible.
Thanks.
Mar 17, 2015 | Office Equipment & Supplies
Printer is not printing yellow, Light Cyan, Cyan, blue lines through Light Magenta & Magenta, What could be causing this and it is also leaking black ink out of the bottom of printer.
Is it under warranty, are you re-filling the cartridges? If yes to first and no to the other two, send it back under warranty. If you use copy cartridges or refill old ones the warranty is vod. This means you need to replace the printer. To be honest, you'd be better off buying an Epson all in one. Even the wireless model start @ sound 40gbp and you can buy good copy cartridges from choicestationery.com
Nov 17, 2014 | HP Photosmart C8180 All-in-one -...
Colors not matching computer
It is possible your colour cartridge has cross contaminated the ink reservoirs. To check this take the colour cartridge out and turn it over to see the coloured pads. They should look red, dark blue, and orange ( the colours are actually Magenta, Cyan, and Yellow, but are concentrated). If any of the pads are pale or particularly green - change the cartridge.
If the colours look alright, your issue is probably that your monitor makes colour by emitting light frequencies so is bright, printed images make colour by absorbing light frequencies so will always be darker. There is always the issue of course that your monitor also has a colour "temperature" bias. Photo pros calibrate their monitors and printers to match.
Mar 25, 2012 | Canon PIXMA iP90v Printer
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
Error message - "some ink
All the ink tanks should be red with no flashing.
The tanks that are flashing or have no red light on , need to be replaced.
Feb 14, 2011 | Office Equipment & Supplies
What does it mean when it says change k cartridge
There should be four ink cartridges inside the printer: Cyan, Magenta, Yellow and blacK.
While monitors build colours out of three emissive (active) base colours, red, green and blue, printers usually build them out of four absorbing (passive) inks, so-called CMYK. The black is referred to by its last letter to avoid confusion with Blue.
On most printers, since they usually print in black ink over white paper (and black is used to darken all other colours), the K cartridge is either bigger than the others, or needs to be replaced more often.
Mar 31, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
Only prints in green and blue
You are more than likely out of magenta (red) ink. That printer uses a tri-color cartridge, and it has cyan (blue) magenta (red) and yellow ink. Green is blue + yellow-therefore you do have those two colors; since it will not print anything red or black you will need to replace both cartridges.
Mar 05, 2010 | Dell 810 All-In-One InkJet Printer
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Pic Bleeding
this sympton is characterized by the presence of red, cyan, green, magenta, blue or yellow colour in a supposedly plain white raster. proper colour reproduction cannot be expected if the raster is coloured. this symptom is caused by a poor white balance adjustment of by a trouble in the CRT, colour amplifier, color demodulation or colour output circuits. if the raster has a tint of red or cyan, check the R-Y output circuits and the first grid, second grid and cathode circuits of the red electron gun. but if you dont know anything about this, just bring it to a qualified service technician. good luck!
Jan 21, 2007 | Sony KV-35S45 35" TV
Videoseven R17PS 17" LCD Monitor Logo
393 people viewed this question
Top Videoseven Computers & Internet Experts
Alun Cox
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Videoseven Computer and Internet Expert? Answer questions, earn points and help others
