Question about Microsoft Computers & Internet
MY PRINTER IS SCANNING TEXTS IN JPEG FORMAT. HOW COULD I EDIT IT?
  • 326 Answers
You would have to enable or use Optical Character Recognition (OCR) or related software that came with your device.
If you need further assistance please provide more information regarding your device.
Please take a moment to rate this solution if you are 100% satisfied.
Posted on Apr 17, 2009
I have a problem after scanning, I cannot bring the document up in MS Word to edit. The document arrives on my computer screen but I can not edit it
You need OCR software installed in your PC
go to www.hp.com then type OCR application then download it in your pc
OCR Application File name: s.gif 23902_hpcom_OCR_120_003.exe [1/1, 54.84M]
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-72836-2&jumpid=reg_R1002_USEN
Text Cannot Be Edited After It Is Scanned to a Word Processing Program
Issue After scanning into a word-processing program, the text in the original is not editable. Workaround The process of changing text from an image to editable text is called optical character recognition (OCR). Text should automatically be converted in the OCR process when the Send To destination is a word-processing program. If it does not, check the items in the following list:
  • Select Editable Text as the image type in Scan Settings . In Windows XP, this setting is automatically selected if Scan Document is selected in the Director program.
  • Scan at a resolution of at least 300 dots per inch (dpi) for correct OCR conversion. Check the default resolutions in the Scan Settings on the Resolution tab.
  • If portions of the scan are cut off, turn off the Auto Crop feature in the Scan Settings on the Scanning tab by clicking to clear the check mark.
  • Tables, text boxes, and spreadsheets might not be editable. The border around them makes the OCR program read them as images. Readiris OCR, which is included with the HP Officejet G and K series, can recognize these images. Instead of selecting the word-processing program in the Send To list, send the scan to Readiris. Use the Table Drawing tool on the right side of the window to change the type of image to a table, and then use the OCR. The text inside of the box should now be editable.
    NOTE: Handwritten messages might not be captured by the OCR process.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
How do I change the default file format from Jpeg to PDF on a xerox M24??
The following information provides an Overview of the Printer's available Scan Settings. 1. To enter the Scan mode, from the Printer's Main (Copy) Screen press the Menu button.
2. On the two-button selection screen, press the right-hand Scan/E-mail button. Note: If you press the lefthand "Copy" button by mistake you will be returned to the Main (Copy) Screen. You will then have to press the Menu button again to return to the two-button selection screen.
3. The Scan screen consists of three Tabs, with each Tab displaying a number of feature settings. From left to right, the three Tabs are labeled: Basic Scanning, Scan Options, and Image Quality/File Format.
4. When the Basic Scanning Tab is selected, three columns of settings are displayed. The first (left-hand) column of settings contains four "Output Color" selections, including: Auto, Full Color, Grayscale (256G), and Black. The second (center) column of settings displays four scan resolutions. The available selections include: 200 dpi, 300 dpi, 400 dpi, and 600 dpi. The third (right-hand) column of settings displays "2 Sided Original" selections including: 1 Sided, 2 Sided (H to H), 2 Sided (H to T), and More.... If you press More..., a screen displays with two setting selection buttons on the left, enabling you to select either 1 Sided or 2 Sided. If you choose 1 Sided, you can select an original orientation of Head to Top, or Head to Left. If you choose 2 Sided, two additional orientation buttons (Head to Head, and Head to Toe) become available for your selection. Note: To support "2 Sided" (Duplex) Scanning you will need to use the Printer's Duplex Automatic Document Feeder. When changing or viewing More... settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
5. After an Output Color is selected from the first column of the Basic Scanning Tab, and the Image Quality/File Format Tab is pressed, a screen is displayed allowing you to choose and configure the settings for Original Type (Text & Photo, Text, Photo), Image Compression (High, Normal, Low), Contrast, File Format, and Auto Exposure.
- Press the Original Type button to select the most effective scanning for your original image type. Options are Text & Photo, Text, and Photo. - Press the File Format button to select your scanned file format. Options are TIFF/JPEG, JPEG, DocuWorks, and PDF. - Press the Lighter/Darker/Contrast button to adjust scanned image density (lightness and darkness) and contrast. Use the supplied arrows to make the desired setting adjustments. - Press the Image Compression button to set the degree of data compression, used especially with JPEG scans. Options are High, Normal (default), and Low. - Press the Auto Exposure button to enable or disable this scanning feature with the ON or OFF buttons. When changing or viewing settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
Mar 28, 2011 | Xerox Workcentre M24 Color Copier
I can't get images to scan in JPEG format, only in the default TIF format, even after selecting JPEG format.
I can help you create a new jpeg file. Open the TIF with Paint program in windows and the save as "Picture_name.jpeg". Once you do that you will have your original file and the new jpeg file that you can edit, and still have the org. unharmed.
Dec 08, 2010 | Agfa SnapScan E52 Flatbed Scanner
CAN'T SCAN TEXT
If you scan the document, make sure it is saved in JPEG format. What you do afterwards is to download FreeOCR. This program is free and works better than most of the ones you purchase.
Just install it in 5 minutes, open your scanned jpeg image and click on OCR button and in seconds, the program will bring it up in editable format for you to change, correct or whatever. Or just click on the OCR MS Word button, and it will open it up in Microsoft Word. Here is the link..
http://www.freewarefiles.com/Free-OCR_pr…
Mar 08, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
How to save scanned image from MX310 to computer?
Save the scanned image as a TIFF for archiving. TIFF files can beresaved and edited without compression loss, thus maintaining the highquality of an image. If you are enlarging an original 4 x 6 photo to8.5 x 11, save the scanned image as a TIFF at 600 dpi resolution. TIFFsprovide more detail than other file formats. Scanned images for emailand posting on the Web, which are to be viewed on a monitor, should besaved as JPEGs at 75 or 100 dpi. JPEGs generate smaller file sizes,which download faster on the Internet. Increase the resolution to 150or 300 dpi only if you are emailing a scanned JPEG image for therecipient to print. Save JPEGs at the maximum quality setting.
Dec 16, 2009 | Canon PIXMA MX310 All-In-One Printer
I have got a DCP-110C printer, how do I scan a document onto the computer then alter the text within this document?
Try this procedure and let me know how it goes
  1. Scan the page you want to convert into a Microsoft Word document.
  2. Save the scanned image in *.gif, *.jpeg or whatever format.
  3. Open that image, go to "File->Save As" and name it "xyz.tiff" in the "TIFF" format as shown.
  4. Go to "Start->Programs->Microsoft Office Tools->Microsoft Office Document Imaging"
  5. Go to "File->Open" and open your scanned document that has been saved in *.TIFF format.
  6. Go to "Tools->Send Text to Word." You will get a prompt stating this process will take time, Click OK. This will take some time depending on your computer's speed (a minute or two at the most).
  7. When it's done it will open up Microsoft word on its own and the scanned document will now be in editable mode.
Sep 26, 2009 | Brother DCP-110C All-In-One InkJet Printer
Printing on photo
Hi
Please scan the document in JPEG format and then take the printout, as TIFF format is suitable for text files and not images. After scanning, check whether the file is in JPEG format or not. If not then you can convert it into JPEG format by using MS Office picture manager or simply MS Paint.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Jul 07, 2009 | Canon PIXMA iP1600 Printer
Change default output from jpeg to pdf
You can't without very expensive Optical Caractor Reader software to convert it. All that scanners do is print thousands of dots that they see from a document into a picture in JPEG format. All they see is dots, not text.
Apr 15, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Scanned a word document, saved as jpeg file
By default all scanned documents are images (jpeg), OCR software converts the image to text for use with Word. I do not believe the scanner can tell what format to use without your input. More information is available here at HP's Online Support.
Dec 31, 2008 | HP Photosmart C5180 All-In-One InkJet...
Scanning
Did you tried with any OCR software to convert the Scanned imaged (jpeg) to Word Documen?.Always if you scan anything to an image, it will scan in JPEG format that will consume lot of memory.Scan with OCR(Optical Character Recognition) Software and that will Convert JPEG to word Document which will fix the problem.
The OCR software that i Recommend is ABBY Fine Reader.
Thanks
Riz
Apr 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Computers & Internet Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
