Showing E002 and not working
In canon np3825,showing code E002 and not working.how can this fault be slved.
    Sniper:
  • 67 Answers
E-002 is an error code for the heat unit in your machine and needs reset, You can try turn it off and unplug it for a couple minutes, plug it back in and turn it back on. The heat lamp or a temp fuse may have blown out in that heat section and need replaced.
Good luck
Bob
Posted on Apr 18, 2009
I REALLY NEED SOMEBODY TO TELL ME WHATS AN E000 IS
You need to formulate your post into a sentence that makes some sort of sense instead of a cryptic error code. You know something like
"I have a Canon MG7120 al in one printer. I was printing, it stopped printing and the display shows E000. Can you tell me what the error is and how to fix it please"?
WHAT DOES SYSTEM ERROR E000 MEAN? - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting
  1. Cached
The error is a system fault error that can sometimes be reset: Follow these steps to reset the error: Press Additional Functions key. Press # Press > to #7 Printer Function Press Set Press > to #4 Printer Reset Press Set Press < Unplug printer and repower it. Ask Your Own Printers Question ...
I have an MF4350d. It is showing SYSTEM ERROR E000. What does ...
  1. Cached
I have an MF4350d. It is showing SYSTEM ERROR E000. What does that mean and what do I need to do? Thanks! - Answered by a verified Technician.
Technology Time: Canon Error E000, E001,E002, E003, E007
www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
  1. Cached
  2. Similar
I described in a previous post that E000, E001, E002, E003 and E007 are fixing unit temperature error codes. Lets go into more detail now. .... I have A problem canon 2002 when i power on the machine then show error E002-0000 pls advice me what i do ? ReplyDelete · Lizpeth G. ... What's prize of cannon copier E354?
Mar 08, 2018 | Office Equipment & Supplies
Error code E002
  1. Press the User Mode key. (Looks like a little man head. Some people call it the function or additional function key.)
  2. Press 2 and 8 on the keypad at the same time.
  3. Press the User Mode key on the control panel.
  4. COPIER Icon
  5. Press the Function icon
  6. Press the Clear Icon
  7. Press the Err Icon
  8. Then ok.
  9. Exit
  10. Power off
  11. Wait 1 min.
  12. And Turn on machine
May 14, 2016 | Canon Office Equipment & Supplies
Sir you tell me how can I reset canon ir 2002n error code e002-0000
Hello . to clear that error you need to replace the fixing heater unit
Apr 25, 2016 | Canon Office Equipment & Supplies
My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
May 25, 2012 | Canon Office Equipment & Supplies
Half of the drum is not appear the image
It sounds like the toner is low in the developer assembly, or problem with toner feed. Canon np3825 uses mono-component toner, if no toner on one area of developement roller, then is blank image there.
Aug 18, 2009 | Canon Office Equipment & Supplies
E002 canon 6317
E002
1)due to fuser unit temperature control fault.
2)try to reset the machine by tuning on and off
3)fixing thermister or thermoswitch faulty due to cannot maintain fixing heater temp causes E002 appear.
4)check any paper roll over the surface of fixing roller.try to remove it.
5)fixing roller or fuser roller located near to printing output.
Jun 10, 2009 | Canon imageCLASS D761 Copier
Canon PC-850 E002 Error Code
After some searching, it appears that this error is common on all Canon Copiers. It means that "Fusing unit not heating up" This is most likely due to a bad fusing unit, or a component the fusing unit. Recommend replacing Fusing Unit.
Mar 19, 2008 | Office Equipment & Supplies
CANON XEROX MODEL 6050
E002 - Fusing unit not heating up.
Replace fuser and reset code, best bet is to contact dealer.
Nov 14, 2007 | Canon NP 6050 Copier
99 people viewed this question
k24674
jasbo
jasbo
