Question about Electric Jazzy 1115 Power Wheelchair
How can you tell when the battery is charging?
I have plugged in the charger line under the joystick and have plugged into electrical outlet. How can I tell on the joystick if the connection is complete? It just shows a red light and I don't know if it is charging.
  • 371 Answers
Your indication that the internal battery on the joystick is charging IS the red light, which in some configurations
may turn to different colors as charging progressses, but if you note no color change, and/or if when you disconnect the joystick from the power, the light either does not stay on or the stick does not operate independantly of the power source, then the internal battery is defective, has exceeded the number of recharges
cycles and/or is fried.
Buy a new set of batteries for all sticks at the same time and play on.
Posted on Apr 17, 2009
How do we charge this chair?
off board chargers plug into the front of the joystick. after 10-12 hrs the chair should be charged, Unless the batteries are bad, or the charger is bad. Plug into joystick before power cord into wall outlet. also charge every night!
Mar 15, 2016 | Health & Beauty
Why isn't battery charging?
hi , have you tried another charger ?
Regards
Rob
Nov 30, 2015 | Pride Mobility Jazzy Select Elite Power...
How to charge the batterry
the charger port is located under the front of the joystick. with the charger off plug the 3 pin connector into the charger port then turn the chrger on or plug it into the wall. You should see a red and a yellow light when the yellow light turns green the batteries are charged turn off the charger and remove the plug from the joystick See my tip on charging Hope this helps you
Jun 05, 2011 | NRS Hoveround MPV 4 - Hovaround Used...
I need to know how to charge the batterie om my sisters merits wheelchair,i do not know how to plug it up,,or if the charger is located on the frame someplace or if its freestanding.plain and simple i do...
sking the off board charger is a 5 inch by 3 inch rectangular box with a power plug on one end and a round silver 3 prong plug on the other. The charger plugs into the charger port located under the front of the joystick. Plug the charger plug into the joystick and then into the wall socket. When it is fully charged the light on the chrager will turn from yellow to green. Unplug the power from the wall socket first then unplug from the joystick In ither words always have the charger unplugged when you plug the charger up to the chair Now if the chair has an onboard charger there should be a power cord that just plugs into the chair usually somewhere in the rear of the chair all you have to do is plug it into a wall socket and charge away Hope this helps you
Mar 10, 2011 | Electric Mobility Merits Electric...
Power chair will not charge
Get new batteries and make sure the charger is charging by checking the voltage at the charger port located under the front of the joystick. With the charger plugged in set a voltmeter to 200vdc and plug the leads into the two outter holes of the charger port. You should be reading 27-32 volts if the charger is working correctly. Without the charger plugged into the wall outlet you will be reading the battery voltage 25-27 volts fully charged Hope this helps you
Feb 24, 2011 | Jet 7 Portable Power Chair
How do you charge the Jazzy 600 powerchair?
With the battery charger That was easy wasn't it? No, take the off board charger plug it into the charger port located under the front of the joystick and then plug it into the wall outlet and let er rip overnight The yellow light on the charger should turn green indicating a full charge disconnect from the wall and then unplug from the joystick and you should be all set Hope this helps
Feb 13, 2011 | Pride New Jazzy 600 Power Wheelchair by...
Batteries are charged, I have checked wire plugs and all are fine, but I have no power at the on-off control. Is there a fuse block, a circuit breaker, or a reset button unseen under the rear lid?
Jerry to make sure you don't have power to the joystick get a digital voltmeter set it to 200 volts dc and plug the leads into the two outter holes of the charger port under the front of the joystick. Fully charged you should read 25-27 volts If you are getting a good voltage then the problem could be in the on/off switch on the joystick. There is a fuse located under the rear shroud somewhere near the power module in line with the cable coming from the on-board charger. If your voltage is real low then you have battery or charger problem. If you plug the charger in and keeping the meter plugged into the charger port you should read 27-34 volts indicating the charger is working and the problem could be the batteries. Try turning the on/off switch on with the charger plugged in the power should come on and flash indicating charge inhibit is working. If you still get nothing check your cable coming from the rear of the chair make sure its fully seated in the plug. Thats all I've got Hope this helps
Nov 15, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Batteries won't charge, bought new batteries and they won't charge either
Moore well it looks like you have a charger problem. With a digital voltmeter plug the on-board charger into the wall then take the voltmeter and plug the two leads into the two outter plug holes of the charger port under the front of the joystick set the meter to 200 volts dc. with the charger plugged in you should read 26-30 volts if you don't get that you are reading just the current battery charge 20-24 volts. If you can try to find someone locally that has an offboard charger and borrow it for a few hours. Plug the offboard charger into the charger port under the front of the joystick and let it charge the new batteries. I would try to find someone with an extra charger you could buy or contact your local provider and have them get you an off board charger to charge your chair. Hope this helps you
Sep 23, 2010 | Jet 3 Ultra Power Chair
I have a jazzy power chair and when you turn it on all the lights come on for about 3 seconds then they go off and all you have is the red lights. we live in alaska so nobody around here to take it to
John Do the red lights blink or steady? this indication on the joystick usually means low batteries. Now this could be caused by bad batteries or a bad charger. On the jazzy if you have an on-board charger the light on the charger will come on green when the batteries are fully charged. If you can look under the rear of the chair you will see the charger and can tell if the light is green with the charger still plugged in after charging overnite. If the light is not lit then you probably have a bad charger. If you have a digital volt meter put it on dc volts 200 volt scale and plug the leads into the two outter charger port holes located under the front of the joystick. Your battery level should read 24-26 volts after charging all nite and with the charger plugged in up to 30 volts if there is no change in the voltage from charger plugged in and not plugged in then the charger is bad. You can then look to purchase an off-board charger that plugs into the joystick charger port to charge your batteries. If your battery readings are lower than 21 volts even after trying the new charger then you will have to replace the batteries. You might try to find someone in the local area that has an off-board charger you could borrow to see if you can get the batteries to charge. This will help you find out if the batteries need replacing. Hope this helps
Aug 25, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Jassy 1103, will not start charging the battery.\r...
the 1103 uses an onboard charger. Charger's life span is about 3 years; some fail in 6 months, some in 6 years keep in mind. You can charge the 1103 using an offboard charger which are available for about $50.00 on Ebay. Search for electric wheelchair charger. You want one that has a 4 to 6 amp rating.
The offboard charger has a 3-prong connector on one end and the other plugs into a grounded wall outlet. Plug the charger into an outlet and the three prong connector into the female three prong connector located at the bottom front of the joystick. Give it a good overnight charge and it should be back up to snuff in the morning.
May 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Electric Jazzy 1115 Power Wheelchair Logo
159 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
