There seems to be a lot of folks having issues with Instagram after updating to iOS7. Make sure you have updated to the latest version of Instagram available. If you still have issues you could try the following which quite a few people have reported fixes the issue:
Hope that helps!
SOURCE: Loading itunes
Simple fix:
For more info refer to pages 97, 104-5 & 111 of the user guide (also available from http://support.apple.com/manuals/#ipodtouch) and the knowledge base article here
All the best
Sean
PiDigital
SOURCE: Determining the ipod problem
If the iPod needs to be updated, try installing the update onto the computer without the iPod attached. Once its finished install the iPod into the computer as normal. It should detect the download automatically.
If the iPod won't charge via USB link cord onto the computer, try buying the adaptor plug socket which you can use without the computer. At least then you'll get a chance to see if the iPod can hold a reasonable charge.
I had a similar problem at Xmas there with a new iPod classic. Eventually I had it replaced as it was found to have problems with the hard disk on the iPod itself. Good luck!
SOURCE: Ipod internet
well! man it`s that your ipod`s firmware or software has some corruption.i don`t know how it came but you can fix it by upgrading your ipod`s firmware using itunes and clicking on check for firmware or upgrade firmware.
even i do have ipod touch and i love it.
take care.
