Question about Maytag Performa PAV2200
Clothes dryer will start, but won't stay on when button released
My clothes dryer, Maytag PYE2300AYW starts when I hold the button in, but will not stay started. It happened after moving it to a new house. The dryer venting is working as I can see and feel the air at the outside vent when I have the button held in. It also is generating heat. The drum spins and all is working as I would expect, but when i release the start button it stops running. When I release the button, the timer is still running (low ticking sound) and will continue to as it had previously when I stopped the dryer by opening the door. I couldn't find my product in the drop-down so it is not the one listed in the Product field.
  • 240 Answers
Could be a number of issues really.  Motor is what I have found to be a problem, the start windings work, but the run windings wont.  Also it could be a timer causing the problems as well.  Both of these cost a bit of money to replace.  Be sure to check the door switch (not usually a problem), buit check it to be sure.  Let me know what you find out, but sure sounds like a motor issue.  If I come up with any other ideas, I will write them right to you.   Jim
PS Also try and check all your wiring inside to be sure something hadn't come loose.  Forgot about the whole moving thing.  Let me know if I can help you with anything else, like getting into the cabinet, etc.   Jim
Posted on Oct 18, 2007
6ya staff
SOURCE:
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
WHY MY MAYTAG DRYER PYE2300AYW WON'T START
Test the thermal fuse on the side of the heater housing. It should read closed for continuity. If open, you will need to replace the kit. Here is a link to the kit you need.
Oct 30, 2012 | Maytag Pye2300ayw Dryer Door Switch...
When we push the button to start dryer it buzzes, it won't go and won't dry clothes. maytag admiral dryer ADG7005AWW
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 19, 2011 | Maytag ADG7005AWW Gas Dryer
Clothes Dryer won't stay on after switch is depressed.
some of them dryers have a switch other than the push button located behind the console. it also has an identical heat switch beside it. if that holding switch is bad it will not stay running. of the two identical switches the run switch is on the left. good kuck.
Jan 20, 2010 | Kenmore Dryers
Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
Jan 11, 2010 | Dryers
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
PUSH TO START BUTTON DOES NOT WORK
its not the start button check the door switch if broken or actuator is broken you get the results as you dry
Aug 21, 2009 | Kenmore Dryers
Problem With Maytag Dryer(PYE2300AYW)
you check the igninter on the burner . does it glow red when started then go off . or nothing at all . it has to glow red for any gas to come out to start the heat to dry your clothes .???
Jul 31, 2008 | Dryers
The motor will need to be replaced. There is a throw-out switch on the motor that keeps it running after you release the start button. These are generally easy to change, with the only hard part being taking the cover off and putting it back on. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=PYE2300ayw&PartCategoryName=&Keywords=motor Any of these motors listed will fit your unit.
Sep 17, 2007 | Maytag PYE2300AY Electric Dryer
Washing Machines Logo
475 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
