Question about Kenmore 76602 / 76604 / 76609
My kenmore elite 766451297 sounds as if the arms are not turning also the dishes are dirty at the end of the cycle
  • 1 more comment
  • rgl8560 Apr 17, 2009
    the model number is 665.13763k601
  • Anonymous Apr 17, 2009
    My maytage wsher ,it sound like its working ,but the dishes come out dirty.
  • rgl8560 Apr 20, 2009
    actually I did do this. The dishwasher is only about 3 yrs old. Anyway, that did not help. The holes were all clear. ther really was not alot fo debris in the sump area.I anm baffled. Thanks for your input
  • 423 Answers
Depending on the age of the dishwasher, worst case your wash pump motor is failing (and will soon fail completely.)
But try this first:
-Check the all wash arms and unblock all holes that are blocked.
-If that does does not help., with a screw driver, remove the screws that holds the filter / shroud to the dishwasher base (under the lower wash arm, which must also be removed.)
-Take digital pictures of each step so you can put it back together.
-Rinse everything that has been removed, especially the filter.
-Inspect with a flashlight the whole sump area, remove all debris (watch out for broken glass!)
-Inspect the impeller to make sure it is not broken and is properly connected.
-Reassemble and test.
If this fails, the motor mention above needs to be replaced.
Posted on Apr 18, 2009
  • Jeff Meyer Apr 20, 2009
    Hi there. Thanks for rating me as helpful.
    Do you have time to post back a quick comment telling me what you found and what fixed the problem? Thanks!!
Kenmore model 665
Power off, check for clogs and if water supply to arm ok. Remove any build ups and reconnect. Good Luck.
Jul 23, 2013 | Dishwashers
Dishes are always dirty, maybe even dirtier after running dishwasher. has hot water, lower arm moves.
Check the outlet holes on both spray arms for clogs. If necessary, remove the spray arms, clean out the holes and empty out any debris inside the spray arms. Verify that the upper arm is turning also.
If the machine does not drain completely at the end of the cycle, the pump drain outlet is partially blocked and you are retaining dirty water for the next load.
You may have a chemistry problem - inferior soap, empty rinse agent dispenser, or extremely hard water.
Improper arrangement of the dishes can prevent some from being washed. Make sure no dish blocks the spray to another.
Jul 23, 2011 | Dishwashers
Kenmore elite dishwaher 1646 not cleaning dishes.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
jklfryyr
Jul 06, 2010 | Kenmore 24 in. 16462 / 16464 / 16469...
Kenmore Dishwasher doesn't rinse? It sounds to be working fine, however, at end of cycle, dishes are still dirty, and the front door on the inside is still dirty. Obviously there is a problem here...
try opening the dishwasher during the wash cycle stop it and open it if water is in the bottom it is filling whn you open do 1 or 2 times to check to see if spry arms are spinning if they are check to see if soap dispenser is working also use dishwasher cleaner once a month available wherever tou shop for groceries in the dish soap dept. directions are on label
Dec 15, 2009 | Kenmore Dishwashers
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
Spray Arms dont work, dishes dirty after cleaning cycle
Do the spray bars rotate easily? If not, you need to remove the spray bars and clean the insides out (do this even if the spray bars do turn easily.). Also check that where they mount is clean and free of debris.
Check the nozzles and make sure they are not plugged.
Also check that the inlet screen to the pump is not clogged (around the bottom of the unit).
Let me know what you find, and tell me if you can hear water spraying inside the unit during a wash cycle (and do the dishes get wet.).
Feb 01, 2009 | KitchenAid KUDR01TJ Dishwasher
Dirty dishes
if water comes into machine then valve is ok.
open machine when in cycle and look to see if spray arms are rotating
if not, then take out and clean.
spray arms only rotate with water jetting out of angled nozzles at end and if these are blocked then no rotation and poor wash
Sep 07, 2008 | Dishwashers
Kenmore 76602 / 76604 / 76609 Logo
206 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
