Question about Intel Computers & Internet
Mobd dp45sg won't post - Intel Computers & Internet
  • Timothy Farley May 11, 2010
    Hi there. Can you run through what happens from the moment you turn the system on, and if you can hear any beeps, also what order the beeps are in, i.e. 1 long 2 short.
  • 4 Answers
Normally you would only hear one beep when the post is successful. If you are hearing a pattern of beeps then your ram memory or video card needs to be reseated in their slots or you have installed incompatible ram memory in your computer.
Posted on Apr 18, 2009
Have a 2005 a1250n Hp computer with Hp ver XP SP3 OS installed. MOBO failed. Can it be replaced by same p/n 5188 1936 using current all ready loaded XP OS. Will GUID be a problem?
If you can get the exact mobo you may replace it. No driver issue will raise. You can also buy a new mobo with same chipset and replace it. Same chipset mobo will require to install Sound, ethernet and vga drivers
Apr 12, 2016 | HP Computers & Internet
Dp45sg 3 beeps
are you sure using proper memory sticks for this mobo?
Mar 23, 2017 | Intel Computers & Internet
My computer lately will only start 5 -7 mins after i pressed the start button. And the motherboard fan is not working too. i experienced the longest start up time is few hours). Extremely slow...
Dude you got ! could be a problem with all of the above..
Most likely power supply. These things are so cheaply made that they simply do not last. Also u mentioned about your mobd fan please check that it turns freely by hand this could cause the problem as well. However i still say power supply
Apr 07, 2011 | Computers & Internet
I have intel dp45sg motherboard sound is not proparly work pls halp????
install mother board driver...or u can use windows7 which havw inbuilt driver.........
Apr 17, 2010 | Intel DP45SG Motherboard
Convert to raid 1 after Vista install
Install at least 2 more hard-drives, and configure them to use RAID.
Then, copy/move all your data-files from "My Documents" onto the new drive-set. The point here is to have "backup" for your files, not for the Operating System files (which can be re-installed from CD/DVD).
Your "programs" can stay on the "current" disk-drive.
Sep 10, 2009 | Intel DP45SG Motherboard
DP45SG won't POST / BOOT
Unplug the unit, remove the battery and the cover for the harddrive then slide out the harddrive Wait for a few minutes and reassemble all parts. It should fire up.This could take a few tries, but it will eventually work. Another outside chance is to remove the cover for the processor and remove the heat sink from on top of the processor and wipe it clean where it contacts the heat sink, do the same to the underside of the heat sink.
Sep 07, 2009 | Computers & Internet
DP45SG problem
Also make sure that you have a stick of RAM in to allow the motherboard to pull up information.
CPU is seated correctly.
If that fails, then reset the CMOS by pulling the jumper off (pins 1-2) and switching them around (pins 2-3).
Hopefully that will get you some video.
Apr 21, 2009 | Computers & Internet
I HAVE A COMPUTER WITH CONFIGURATION OF INTEL EXTREME DP45SG MOTHERBOARD,QUAD CORE 6600 PROCESSOR,NVIDIA GRAPHIC CARD,DDR3 RAM(1333 HZ),500GB HDD(SEAGATE) and still my compuer screen shows NO DISPLAY...
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button.
Try to boot the pc.
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker, put the powersupply in a different pc, or try a different powersupply in the problem computer.
Ok try all this first...
Feb 27, 2009 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
268 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
