Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Printing envelopes How do I print envelopes using Word Perfect on the Canon ImageClass MF6530 printer?
  • tomd71 Feb 22, 2009
    im showing a paper jam an my mf 6530 and i see nothing
  • Anonymous Mar 27, 2014
    toner low
  • 3 Answers
You will probably have to change your paper settings on the printer itself to proceed without an error. In the additional settings>Paper Size> change it from Ltr to Envelope.
Posted on Jan 09, 2008
    New Friend:
This might be helpful, but isn't for WordPerfect -- it's for OpenOffice. However, there might be some crossover.
http://baitisj.blogspot.com/2010/05/printing-envelopes-on-canon-imageclass.html
Posted on May 05, 2010
SOURCE:
Copies are not printing and I have shaken the toner.
Perhaps it's time to get a new toner as the one you've been using is totally empty.
Jan 19, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Canon imageclass mf 6530 blank pages change toners still blank what is the cause of this problem
you have problem with laser shuter on laser unit. It needs to be fixed or replaced.
This is canons factory fault, and if the machine is under waranty call service.
Hope that helped!
Jul 19, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Printer was working one minute, stopped printing the next.
Found this info somewhere else.
One other note: After just less than one year of moderate use, the machine completely stopped printing; all output was blank pieces of paper, both printing and copying. Canon technical support was very good. The printer has a three-year warrantly, and within the first year free on-site repair is available. The day after I called Canon (and immediately got a professional, articulate support rep), a friendly repairman came to our office and replaced the laser shutter. The machine is now working well again...and hopefully will for the rest of its life.
I know of another machine which has this fault that is why I'm looking on the internet for an answer. Hope that helps you out
Mar 19, 2009 | Canon imageCLASS MF6560 All-In-One Laser...
Canon imageclass MF6530
try ( add.function & #) service mode and then find clear all
Feb 26, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Canon imageCLASS MF6530; can't set up duplex (2sided) printing
hi there
there are 2 ways to copy 2 sided
one is full duplex which means your copier must have a duplex attatchment fitted on the copier lid
the other if it hasn't got a duplexer is to copy in 1 to 2 mode which means you have to turn the copy over. it sounds like your machine has not got a duplexer fitted but it can still do double sided using 1 to 2.
hope this helps
beergut707
Oct 15, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Print copy is reduced
Go to the printer menu and check those settings. It is a configuration problem
Oct 12, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Printing in color
Because is not a COLOR printer, it's monochrome!!!
Jul 16, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Canon Imageclass MF6530
the imageclass MF6530 cannot print in color it can only print in black and white. the only thing that this machine can do with color is to scan color documents to your computer otherwise it is a black and white copier and printer with color scan.
Jan 02, 2008 | Office Equipment & Supplies
Canon imageClass MF6530
This is a "monochome printer" ie B/W, double sided is called duplex select this option on printer driver on pc
Dec 01, 2007 | Canon imageCLASS MF6530 Monochrome Laser...
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
733 people viewed this question
Clive
Clive
old marine
old marine
Ekse
