Question about Saeco Royal Professional Espresso Machine
No power My son spilt water all over the machine when trying to fill the water tank. Now it will not power on. Any ideas?
    President:
  • 1,618 Answers
Open the machine and use a fan or a blowdrier to dry out the machine, there may be water on the micro switches which may have caused a burnout. Check the Main switch and the capacitor which sits under the pump.
Posted on May 16, 2009
I have a Gaggia Syncrony Compact Classic Semiautomatic. The water light is flashing red, tank is full, and I can't get any water through the steam nozzle either.
First, I'm not a Gaggia technician.
- Water not getting to machine or not sensing that the water tank is already filled.
* There usually some type of float near to middle of the water tank. It's usually white or colored plastic. This 'float' needs to move freely up-down to 'sense' the filled tank. clean the tank and shake it -note the movement of this float. It will need further cleaning if it's stuck (or you will have to replace tank if it's crudded up).
* Re-install tank and fill with filtered water. Turn machine off, count to 15 then turn on again. This usually turns on pump to add water to inner tank. If this does not happen then there is a CPU problem. If it does hums for 5-10 seconds then goes off but no heating then the pump may have an air bubble in line. Try the turn off and on method several times (up to 5) to get the water flowing. If it's still not working then there is a clog in the pump and will need service and/or replacement.
* Did you change water source? Since this is a table top machine in which you fill the water tank. Try to use filtered (bottled ok) water. Do Not use Distilled or 100% pure water as this type of water will eat out the metals from your machine! Some places use a water softener as it tends to be better for the machine long term (years).
* Still got problems? Check with vendor or MFR for service or replacement. Most machines of this type do not have serviceable parts or adjustments.
Aloha, ukeboy57
Jan 09, 2018 | Coffee Makers & Espresso Machines
Why standby light active and water tank fill light is blinking ?
It shouldn't harm it plus if the scale is affecting the switch for the watertank then it should sort it out....
Jul 25, 2014 | Bosch Tassimo TAS4011GB Coffee Maker
Fill water tank
First, I'm not a Saeco technician.But I've worked on similar Saeco machines.
Aloha, ukeboy57
Aug 08, 2013 | Saeco Royal Professional Espresso Machine
Franke Saphira - fill water tank
There is a magnet fitted in the side of the tank. Lift out the tank and make sure the magnet is free to move. It might be that some water has been spilt onto it and it's crusted up. Failing that, suspect a faulty microswitch inside.
Jan 24, 2010 | Franke Saphira Espresso & Coffee Maker
Fill watertank message will not go away
This happened on my unit. There is a magnetic float in the tank that rises when the tank is filled. On my unit, the float (which is supposed to be sealed) took on some water, and stopped being bouyant. I had to break off the clear plastic cap that keeps the float in place, remove the float, and ***** a tiny hole in the float and squeeze out the water. Now (since I have a hole) I have to do this repeatedly - every week or so - though its easy to remove the cap now. Still looking for a replacement part.
Dec 30, 2008 | Gaggia Titanium Espresso Machine
Saeco Royal Exclusive 30153... FILL WATERTANK
Hi Marty,
Make sure the magnet in the water tank flow up when you fill the water tank with water.
Aug 07, 2008 | Saeco Royal Exclusive 30153 Espresso...
Water Light
If you look in the water tank you can see a little magnet in the down corner, make sure that magnet flow up when you fill the water tank.
Jul 29, 2008 | Saeco Incanto Classic Espresso Machine
Nespresso Magimix M300 'Fill Water'
it just means that the pump needs primed. Turn on at the wall and on the machine, wait until screen says ready (make sure water tank full), then turn steam handle on RHS to on (do not push the steam button). the pump will prime until water comes out of the steam nozzle. now turn off the steam handle and you are ready to go!
Sep 16, 2007 | Coffee Makers & Espresso Machines
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Saeco Royal Professional Espresso Machine Logo
62 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
