Question about Samsung HC-P4741W 47" Rear Projection HDTV-Ready Television
Picture Looks Like a 3-d Movie
Turned TV in this morning and while center of picture looks fine, to the right side it looks like a 3-d movie with a different color giving the same image, looks like colors are not lining up. What can I do to fix?
  • Anonymous Aug 03, 2008
    Yes the whole picture is off wak. the red is really off line shadowing everything. I figured it was the convergence . i have a Panasonic 47 inch and you can manually adjust the convergance. I guess on this one you cant.
  • 71 Answers
This is bad convergence. Try self focus and if still not ok is hardware problem. The STK are leaked and need to be replaced. It's not easy, you have to remove the all deflection board and for sure you'll have some resistors to replace too. I sugest you to call a tech, but first try the self focus.
Posted on Dec 07, 2007
Sony KPR-53EXR15 pictures fades in and out
Sounds like possibly it could be connection related between any AV/Cable ports. Worst case would be the capacitors of the motherboard leaking. It's possible to fix anything. Just make sure you have the knowledge and the right equipment.
Mar 31, 2017 | Televison & Video
I turned My tv on and the top of the screen has red, green, and blue swirl lines, and the rest of it looks like watching a 3D movie without glasses, and the picture looks as if you took out the screen and...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or pictures look like 3D?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Aug 11, 2011 | RCA D52W19 52" Rear Projection Television
I have a Panasoniv 32 inch vivera lcd tv. When I watch a movie the picture looks grainy. Kind of like the pixels are not forming to complete the picture. Am I missing a cable or some kind of compnent for...
If you're watching the movie from a DVD player, make sure all of the cables are fully plugged in and connected. If you're watching the movie from a VHS, it will probably continue to look like that.
Feb 28, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Dvd picture is darker than tv picture
Most sets have electronic service adjustments. Contact manufacture for nearest service center.
Mar 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Convergence Issue?
1 read the manual,2 look under convergance,3 follow the instructions.if you can not do 1,2 or
find a hetrosexualman that can read and make him dinner.If you do not have a manual look up the manufacture and you will be able to down load one for free.
Jan 18, 2009 | Mitsubishi WS-55807 TV
Convergence Issue?
I had the same problem but not as bad. I went to the menu, then settings. Tried the factory convergence reset first but that didn't work. Under convergence I selected the red option and got a screen with a plus sign. Press the AUDIO button and lines will cover your tv screen. It might take a while but you can try to fix the convergence at many points now. Select the area you want to correct by pushing the ENTER button, then up,down,left,right until its better and ENTER button again. Keep doing that to all areas. Once done with red, push VIDEO button and blue convergence will come up. Also INFO button helps explain a little. After I did this my picture improved a lot. My tv wasn't as bad as yours, but I hope this works.
Jan 09, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
Picture problem on mitsubishi medallion ws 55819 model....picture convergence messed up on left and right side of screen (center fine)...problem goes away and set "re-adjusts" after it's been turned on for...
Well I have a Mitsubishi WS-65413 65 in. Rear Projection Television and when I power it on in the morning it looks as if the picture on the bottom of the screen is bending and parts of the picture "double up" but like the person above me said after it gets warmed up it goes back to normal but every 3 or 4 hours it might get messed up for a min...Anyways: Is it the picture tube going out?? If so how does anyone know how much it would cost to repair/replace & What is a "Convergence Module"?? I don't know if my T.V has one of those or not but if it doesnt is that the problem perhaps?? Please help me or ill be forced to go outside... :-( ..... thanx 4 the help ppl!! -
- Zachariah-
May 10, 2008 | Mitsubishi WS-65413 65" Rear Projection...
3d picture
Bad convergance amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 27, 2007 | RCA HD52W58 52" TV
Samsung HC-P4741W 47" Rear Projection HDTV-Ready Television Logo
268 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
