The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
I found the manual for this model weed eater, according to the manual the mixture... and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be mixed at a Ratio of 40:1 ...." and I quote once more from the manual "Helpful Tip. To obtain correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps, If you like I can send the manual via email if you need it.
Don't know that exact trimmer, but I always run 40:1 in all my trimmers, chainsaws, etc. That is 3.2 oz. of 2 cycle oil to one gallon of gasoline. I rebuild these machines daily and run that mix in everyting, except when it's actually specified on the machine.
FUELING ENGINE
WARNING: Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
